The trafficator cancelling ring in our BN7 (adjustable steering wheel) is not fixed to it's short upper portion of the stator tube. In other words, you can rotate it around the stator tube. It appears as though someone attempted to weld it in place, presumeably to prevent it from rotating. Not sure why. The electrical system works fine. But mechanically it's unreliable. Sometimes it won't cancel and you have to do it manually. Other times you can't get the trafficator to budge (rotating the steering wheel back and forth a few times corrects this problem). Yet before we reinstalled it after the rebuild we could get it to cancel just fine. What's going on in there?
