Tracing the opening of a AH 100-4 rear fender
Jonny1
I am trying to over come major flared rear fenders on my 1956 100-4 and would like to bring them back to a stock opening. I have a very talented metal working friend who can do this if I can supply a tracing of the opening of one rear fender. I understand that the rear fenders are the same from 1950's to 1967 unless corrected here on the forum. I would be very happy compensate anyone willing to supply a tracing.
I'd do one from my 100/6 for you on some posterboard, but my car is presently located offsite, and I'm not sure when I'll get to see it again.
With any luck, someone a lot closer to you will come to your rescue!
If you tell me exactly how you'd like it traced I can do it as my fenders are off the car. Do you just want the fender laying flat on a piece of kraft paper and traced as if I'm shining a light straight down and I trace the shadow?
rich
Thanks Rich!! Yes that would be great exactly as you described. My address is:
Jonathan Leet
3801 N 64th St.
Scottsdale,AZ 85251
Again, I know this a major pain and I will be happy to compensate you for your time, materials and postage.
Thank you also Randy for answering.
Jonathan
Would a good digital picture with dimensions work? That way you can print out the picture on 8.5 x 11 and then bring it to kinko's and have them expand it / plot it to real size?
Jonny,
Here is what I was talking about. You can grab this image (or I can send you the file), print it on 8.5 x 11 and then figure out how much you would need to expand it to get that lower dimension correct. I've used this method on a number of metal working projects with success. It does not take into account compounded curves, but not sure how you would do that from a tracing either. Let me know if there is anything else I could do to help.
Jonny1 said:
... I have a very talented metal working friend who can do this if I can supply a tracing of the opening of one rear fender...
Can your friend reproduce the wrapped-wire bead? If so, I'd be interested in how it's done.
Hello Rich,
I hope this note catches you before you go to the trouble of tracing the opening for me. You are very kind to offer. Healey Z has come up with the solution of working off his Healey fender pics and expanding them at Kinkos to the right size.
Hello HealeyZ,
I have grabbed the photos and will follow you instructions. This will be easier
because the back half of the fender is still original.
Thank you Rich
Thank you Healey Z
You are both good gentlemen!
Hello Healey Z,
Thanks for your help. It will not have to bother you to take the wheel off
because, thanks to you, we have all the info we need.
Best regards,
Jonathan
