Wedge TR8 fuel pump options
tdskip
Hi folks - looks like my TR8 (carb model) fuel pump is toast.
I've heard of talk of using "over the counter" replacement pumps that are in stock at NAPA and others that we a direct fit, but much less expensive.
Any one with first hand experience here?
Thanks,
Tom
Re: IveTR8 fuel pump options
I've had a NAPA universal in my 8 for the past 4 years and 6,000 miles with no problems at all running an Edelbrock 500 carb. I think it cost all of $20-25 and I used the existing fuel line running right through the old pump so it was a very simple fix. Best thing about it is I know if it craps on the road I can easily pick up a replacement at my friendly NAPA dealer.
Tom
I have used a after market one for 6 years, 30,000 miles with no trouble. I installed it under the hood and it took me 20 miutens to do it too.
There are intank pumps that cross over. I did find mine at a local Napa. Wedgeparts has a crossover list on his website for intank pumps. If I find my reciept with a part number I'll let you know.
So is there any really reason I need a functioning in-tank pump instead of an external pump to pull through the existing non/under functioning one?
Well, IMHO, the intank pump is very easy to change (the tank does not have to be removed) if the tank level is low enough. A correct crossover pump doesn't need a pressure regulator. You don't have to drill and tap mount holes for an aftermarket out of tank pump and you don't have to modify any wiring for the new pump. I haven't found my reciept but I think the pump and filter sock I bought were also less expensive than the universal aftermarket items.
BTW, Woody is supposed to have new intank pumps sitting on his shelf ready for sale. And here is a link to the Wedgeparts crossover list .
Yes you can run a external pump, but you need to remember that you may need pull fuel thru a dirty sock and the fuel pump itself. TR8 carb cars power for the pump goes from the ingnition switch, oil pressure switch, inertia switch to the pump.You need to to check these items first to correctly find your problem. If you decide to run a external pump I would still suggest you remove the original pump and install an TR7 sender so you can pull the fuel thru it without any restriction. Personally for 68.00 dollars I would just put an orginal pump in and know it works as good as the original.
Woody
Welcome, Woody! Great to have you on board here.
Mickey
Tom
Hi. Mine crapped out too. So I can install one under the hood? I assume after the filter. Which pump from Napa did you get? Thanks John
