Wedge TR7 Carburetor losing dashpot oil
Deleted member 13031
The previous owner installed manual choke carburetors on my US market 1980 TR7. It has a pair of ZS CD175's. The car runs resonably well and starts fine. Idle and acceleration are a bit sputtery, but the biggest problem is that the forward carb loses its dashpot oil over 3 days even if it is not used, and 150 km if it is. The rear carb needs a dashpot top up every 60 days or 500 km. I tried different fluids but that is just avoiding the repair. I had a mechanic replace the needle "o" rings with no change.
The previous owned cannot tell me what the carburettors came off. He says they are original TR7 carbs but i don't think there was a North American TR7 with factory manual choke. In addition to this, one carb had a vented plunger knob and the the other didn't. The mechanic drilled a hole in the non-vented knob(?). They are black in colour.
What is going on? Could it be the wrong needles? Could the diaphragm be leaking? Could it be the wrong "o" rings? There is no good local service for Triumph or Zenith Stromberg carburetors. The little brass ID tag is missing off both carbs. I am reluctant to take the carbs off the car and send them away because the car is in paid storage only until May. If i don't get the carbs back on the car and get it out of the garage it will cost me $125 per month.
Does anyone have a solution, suggestion or a set of carburettors?
Geoff
DNK
The manual choke kit can be bought after market so the carbs could be correct
dklawson
+1 on Tdskip's post. However, "not having to take the carbs apart" depends on your definition of the task. Since replacing the needle o-rings involves taking the piston out and disturbing the needle location (fuel/air mix) I consider this a task that not everyone is up to. However, it is not beyond the scope for a confident DIYer using the instructions in the article linked above. Just remember if you do this task yourself you will need to tune the carbs after you are done.
TR3driver
Great Pumpkin - R.I.P
Very likely, the vent hole was not required and the vented knob is from some other carb. The space under the knob does need to be vented, but all of the CD175s that I've seen have an internal vent for that space.
However, since you say your mechanic has already replaced the O-rings once and you're still losing oil; I wonder if perhaps you are overfilling. As long as you can feel resistance for the last 1/4" or so of travel when you insert the plunger, there is "enough" oil. If you put in too much, it leaks out through the vent and through the sliding joint.
George_H
Didn't 75-76 tr7s have manual chokes?? Also, I put new o-rings in last year and one carb still uses twice the oil of the other.
poolboy
Some of the O-rings that seal the damper well might be a bit loose on the adjuster and that may be why they leak.
I've noticed that on several carbs that had their O-rings recently replaced, yet leak. I didn't ask where they came from. I get mine from Joe Curto.
NeilRogers
Canadian TR7s all had manual chokes unless, of course, they were fuel injected.
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
K Wedge TR7 Project Triumph 10
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
L Wedge TR7 gasoline odour Triumph 5
tr7andtvr Wedge Tr7/8 rear end ID RKC0100 Triumph 4
waltesefalcon Wedge Looking at a TR7 Triumph 6
