Phil-
My '73 had a piece of jumper wire installed (It did look like a hack) when I bought it.
(I'm running a Ford EDIS system right now, though).
You could incorporate the wire into the loom. I think, looking at the wiring diagrams, you could just stick it on the same terminal of the fuse block that the white wire from the ignition runs to--that's about what the '72 did. Can't hurt to make a jumper with spades on each end and try--if it works, you can pretty it up later.
Best of luck, and let us know, hey?
