TR6 TR6 wires
DNK
Can someone measure the wires for each plug and report back the length including the boot? I tossed mine a couple of months ago.
Thanks \Don
Don,
Are you hand crafting a set of wires?
If so, I could really use a No.1 plug wire.
The Moss set I got has the No.1 so short it barely
reached the plug.
I go measure the wires and get back to you.
d
Don- These measurements are from my spare set of Roadster
Factory plug wires. Total lengths including boots.
#1 at 18"
#2 at 16"
#3 at 12 1/2"
#4 at 11 1/2"
#5 at 12 1/4"
#6 at 13 1/2"
coil to dizzy at 12"
hope this helps,
dale
/bcforum/images/%%GRAEMLIN_URL%%/banana.gif /bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Personally, I like the wires as short as practical for a neat appaearance plus (on a 4-cyl at least) makes it impossible to connect them incorrectly.
From a 'universal' 8-cylinder set of copper core wires from CarQuest I can fashion 4 or 5 sets of 4 cylinder wires.
I also like the right-angle connectors that snap onto the plug rather than the tight fitting boot -- I can actually pull one of those off a running engine w/o a shock.
None of this addresses the question... just some random plug wire comments.
The Roadster Factory green wires fit perfectly. I was pleasantly surprised at the quality too.
Stirkle:
I have a set of green TRF wires I carry as emergency backup
for use during break downs. My TR6 has a GM conversion
alternator.
I was told the green wires would not last very long with an
alternator of higher amps than the old Lucas generators.
I installed the thicker Moss blue plug wires.
Do you know if it is true about the green wires burning up
with use of the GM product?
thanks,
d
I'm the wrong guy to ask about that because my alternator is Lucas and I wouldn't use a GM or Bosch anyway. They are probably better, but I'm an "if it ain't broke..." guy.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Do you know if it is true about the green wires burning up with use of the GM product? [/QUOTE]
I would like the person who originated that quote to explain that theory to me. Not you Dale, whoever told you that.
Oh absolutely !
GM alternators do not contain enough smoke to replenish the normal leakage from genuine Lucas wiring products (which of course is why they can put out more current : no room taken up by the smoke). And as everyone knows, once the smoke leaks out, the wiring won't work.
