MGB TR6 wheels for an MGB?
bash
This may be a silly question, but has anyone tried fitting TR6 steel wheels to an MGB? It is a rubber bumper car if that matters.
Cheers
Alistair
BOXoROCKS
TR6 wheels, chrome bumper car,forget the flairs in front,look at the back,a tight fit, but it fit
Steve_S
It's sitting pretty high, too. Return that to stock height and there's no way it will fit unless you run really skinny tires.
You can use a wire wheel axle modified to fit bolt-on hubs, then bolt up the TR-6 wheels. I'm not sure if the track would then be correct but it would be a lot closer!
Steve_S
There is a LOT more space above the wheels than standard though! Typically the rear fender lip covers the top of the tire, and that's with a small tire installed. those look like at least 185/70R15 which is much taller than stock. Perhaps your springs are too stiff, as are many repros these days.
Here's a photo of the stock fit with steel wheels. Look at the amount of dish on the TR6 compared to the MGB wheels. I have TR6 wheels here I can measure if necessary, but by eye I would guess at a 1-2" difference per side.
bash
bash
Thanks for the advice. I got the TR6 wheels anyway (part of a bunch of parts I bought without working out where to store them) and they are actually early TR6 (or TR250) wheels which are 5.5 inch wide rather than 6 inch of the later wheels, which seems to fit a bit better. They look way too big with the redline tyres (MGBigfoot seemed like an appropriate nickname), but with lower profile tyres they might look okay. I will have to think about it and decide if it is worth trying.
Cheers
Alistair
PAUL161
Was that Johnny Cashes car? One piece at a time? :highly_amused:
billspohn
It is pretty tight for that sort of offset on the rear of an MGB. I run TR-6 (5.5') wires on my MGC with no issues but they don't have as much offset as the steel wheels did.
The MGA is much less demanding - these are 5.5' Dunlop wheels on my deluxe coupe, with about the same offset as the TR-6 steel wheels.
bertrand
The rear is indeed tight, in particular the right side as the axle is not correctly centered. The left side don't rub, but the right side do sometimes.
Following your experience is it possible to better centre the axle ? the difference is about 10 mm.
billspohn
Centering the axle can be as easy as loosening the U bolt nuts, levering it to the side and retightening, or it can requite a Panhard rod or relocating the spring seats on the axle. you just have to try and see.
R MGB TR6 wheels on MGB? MG 4
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
Joel Lester Wanted Wanted - TR6 steel wheels Triumph Classifieds 6
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
T For Sale Tr6 Original Wire Wheels with Knock-offs Triumph Classifieds 0
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
J TR6 What are Original TR6 wheels with Michelin Red Lines worth? Triumph 11
B TR6 Help me choose new wheels for72 TR6 Triumph 7
B TR6 Advice on Wheels for a 72 TR6 Triumph 2
W TR6 TR6 front wheels Triumph 7
T TR6 TR3 hubcaps on TR6 wheels on a TR3 Triumph 11
T TR6 14x7 wheels feasible for a TR4 or Tr6? Triumph 10
Brosky TR6 Custome TR6 Knock-Off wheels....OK.... Triumph 1
H TR6 TR6 Wheels Triumph 9
I TR6 Powdercoating TR6 wheels Triumph 5
Brosky TR6 Konig 15X7 wheels on TR6 - No mod fit? Triumph 22
B TR6 Dunlop 72 spoke wire wheels TR6 Triumph 6
Slider748 TR6 Wire wheels on TR6 [picture] Triumph 8
Steve_S TR6 Wanted: TR6 wheels for test project Triumph 0
B TR6 TR6 wheels fit a TR4A? Triumph 5
T TR6 Nissan wheels on a Tr6 Triumph 26
2 TR6 Konig Wheels for TR6 Triumph 14
T TR6 After Market steering wheels - TR6 Triumph 3
71tr TR6 new wheels for the TR6 Triumph 17
boxofparts TR6 tr6 revolution wheels and offfset spacers Triumph 2
MrPandy TR6 Konig Rewind wheels - TR6 Triumph 14
T TR6 Wheels that fit a TR6 Triumph 4
milemarker60 TR6 8 Inch Wide Wheels on a TR6??? Triumph 2
Brosky TR6 Has anyone ever chromed or seen chrome TR6 wheels? Triumph 3
A TR6 TR6 Wheels Triumph 2
P TR6 TR6 wheels - free for the taking Triumph 10
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
