TR6 TR6 trailing arm stud upgrade?
TR6BILL
BobbyD said:
And on that note he grabs that hunk of cheese to go with his whine err wine
"The cheese is old and moldy...." -- <span style="font-style: italic">Encino Man</span>
I need my tool. Stop whining.....
T
Tinster
BobbyD-
I kinda got lost in this thread.
Is your process to be used AFTER helicoils have pulled out?
Or AFTER the 5/16" fine thread T/A studs have pulled out?
Or is this a new process to be used with factory 5/16"
still in place and nothing stripped out or ruined?
The circular plate in your final "how to" photo-
is that the finished T/A upgrade plate ? If not, do
you have a photo of an upgraged T/A, in place,
in the car you could post.
I was told that once my helicoils had all stripped out
that the T/A was then useless and to trashcan it. I did.
But I was real tempted to thrubolt it.
Thanks
Brosky
That will probably be the final look of the plate Dale, but this is still in development. I'm sure that Bobby will post some pictures of his completed T/A's soon, since it's going to rain for the next two days and you don't need a snowblower in the rain.
Of course he'll probably have some lame excuse like Christmas or some holiday getting in the way, but Bill and I are still optimistic about seeing the tools from Rick by March.
I suppose you could sat that this will work with the KeenSerts as long as the hole(s) has not gone beyond the .397" diameter that the "X" drill makes for the tapping of the 7/16" threads.
BobbyD
Dale..... this process is for use after the Heli-coils have pulled, the wheel has flown off..........taking out a number of innocent by-standers........and the memorial service has been held for those riding in the car. Pedro will use this kit to repair the car for the next innocent victum and resell it at a substantial profit. Ho Ho Ho.........Santa is watching.
Paul ..... my excuse is that my 85 & 87 year old in-laws have invited a friend to Xmas eve dinner at our house who doesn't eat seafood.........after I've, yes me. has bought and prepared the seafood dinner. So tomorrow morning, I'm off to Stop & Shop for more F@#&ing food! I love my in-laws. :wall:
Merry Christmas everyone!
Brosky
Just kidding as usual Bob, but your family story is funnier.
Merry Christmas to you and the "Man Who Came To Dinner".
crj7driver
I finally talked myself into purchasing one as well. The further I go in this project the more I find I need to reinforce or theoretically make better. That along with the 300+ RWHP I am throwing at this thing has me doing a lot of "just to be one the safe side measures". Now if I can assemble this thing with my eyes closed I might not see anything else that needs a "little improving".
T
Tinster
BobbyD-
I am wondering if your upgrade will increase the shear values as well.
My helicoils not only pulled out of the aluminum T/A
and stripped the threads; there was also some shear
failure of the aluminum that broke off chunks of the aluminum.
I still take road bends like an old lady for fear
I'll have another rear wheel pop off.
d
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]That along with the 300+ RWHP[/QUOTE]
What are you putting in that bad boy and do you have any pictures of the progress?
Brosky
Dale,
I would think that putting a locking steel insert into the aluminum casting with the coarse threads can only help the original design, but without some sort of a full blown stress analysis, we'd only be guessing, right? They company claims that you can shear off a grade 8 bolt in the insert without having it move from it's locked in position, so it's really all we have to go on.
How would you go about actually measuring that value without having a fully destructive test of the insert and the affected area? Or is there a way to do it in a non destructive process?
T
Tinster
Paul, as T/A stud...........destructive test, I'm afraid.
It's like a steel telephone pole sunk into the earth.
The taller the pole, the deeper it must be sunk
or a huge mass of concrete poured as a footing.
Tie a steel cable to the top of the telephone pole,
hook the other end it to a D-10 Cat and a strain
gauge and pull. You are attempting to "overturn"
the pole.
The T/A aluminum is like the soil- softer than the steel.
In theory, a wider/taller T/A steel stud requires addition
depth sunk into the aluminum for overturn moment.
In hundreds of field "pull" tests, I always got much higher
results from finer threads. Wood, steel aluminum, concrete,
brick- it did not seem to matter. The finer threads were
always more difficult to "pull" to failure.
just my 2 cents on pull testing,
d
d
M TR6 GoodParts Adjustable Trailing Arm Brackets TR6 Triumph 14
TR6BobNF TR6 TR6 Trailing Arm Bracket - Crack Triumph 10
SCguy TR6 TR6 Trailing arm question Triumph 10
I TR6 TR6 rear hub and trailing arm spares advice Triumph 2
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
I TR6 TR6 trailing arm bushing installation help Triumph 24
M TR6 TR6 trailing arm bracket bolts - Help! Triumph 9
G TR6 Rear suspension [trailing arm] adjustment on a TR6 Triumph 18
tr6web TR6 Bumper stop on trailing arm - TR6 Triumph 5
TR4nut TR6 Ballpark cost - TR6 trailing arms? Triumph 4
T Wanted TR6 rear trailing arms Triumph Classifieds 1
SCguy TR6 TR6 Trailing Arms Triumph 2
SCguy TR6 TR6 trailing Arms bushing removal? Triumph 11
G TR6 Trailing a TR6 Triumph 4
A TR6 TR6 REAR TRAILING ARMS AND BETTER HANDLING Triumph 7
Hawk813 TR6 TR6 Brakes Triumph 4
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
