When posting a classified ad, you MUST select a prefix from the drop-down next to the subject line. If you don't you will get an error and your ad will not be posted!
Can anyone on the forum tell me if the surrey top...which
I usually see on a TR4... fit on a TR6? IF it can...do you need to make any modifications to the surrey top? Thanks, Gil
I can tell you that I have seen a surrey top fitted on a TR6. As far as what mods are required, I can't help you there. If you are stuck for an answer, I can find out for you.
Strictly a guess, but I would say no modifications would be needed other than whatever mount points might need to be fitted, including possibly changing the header rail finisher? Hopefully someone will know better; might even be a question for the TR Register Forum (if it hasn't already been addressed there):
Wasn't there a Lee Janssen on here from Colorado who, in addition to building his own turbocharging system, fit a surrey top to his TR6? So I know it can be done. Shawn Loseke knows him so if he doesn't chime in soon, you might send him a PM and ask him about Lee.
The only modification is that you need a to use a tr4 windscreen frame top cover plate. Roadster factory has all the the mounting hardware and seals including the tr4 top plate-------other than the top plate it should mount just like on a tr4
