TR6 TR6 Oil Folter Removal
fwtexasbj8
I bought my wife a TR6 for Christmas last year and while I was changing the oil in my Healey yesterday, thought I would just take care of hers as well. What a pain and mess!
How do you get the dang filter cannister out??? It will not fit between the engine and frame from the bottom and is locked in by the fuel pump & filter, the distributor and what I suspect is the oil pressure line into the block. I have searched the forum and found lots of posts ablut converting to a spin on filter, which will be in the mail before I do that job again, but cannot see how to get it out to convert. Am I just stupid and missing something? Also, the Crosslands filter I installed was slightly different than the one I removed. The new one had one end closed with a perforated cover. I installed it on the engine side, but now am questioning that decision. Has anyone seen a filter like that and does it matter which way it is installed?
Thanks for your help,
Doug
poolboy
It is a problem with LHD TR6's. I loosened the drive shaft; others remove the clutch slave.
If you just want to clean the sludge out the can, I'd work around it, but if you need to replace the seal around the bolt or better yet, replace it with a Mocal spin on adaptor then it needs to be removed
M_Pied_Lourd
Steering shaft PB? :smile:
Cheers,
Tush
mallard
I used the original style filter for many years and was always able to remove it without moving anything else. It made a mess of the garage floor, but you just wipe it up. If I remember correctly you loosen the bolt to remove the can and then pull the can with the bolt still in it up and to the back of the car. Then the filter can drop out the bottom. With the filter out of the can you should be able to rotate the can up so you can clean it out. Remember to get a small hook and remove the o-ring that is in the block and replace with the new one.
poolboy
"Steering shaft PB? "
:thankyousign: :crazy: Right. Steering shaft and not even all the way, just one bolt at the rubber coupling and swiveled it on the other looseed bolt.
Gliderman8
Poolboy... I too stilll have the original oil filter can. Can you supply a model number for the Mocal spin on? Where does it mount? Pics?
BTW, I had my drive shaft halfway out before I saw your correction :whistle:
poolboy
You was kidding right ?
I got the Mocal spin on adaptor from British Parts Northwest.
It's the improved version according to their description.
It just replaces the canister as far as location, but just about everyone that I'm aware of installs it twisted slightly so the bottom of the actual filter does not touch the clutch slave cylinder.
Somewhere between 7 & 8 o'clock seems to do it.
As far as which filter, the NAPA Gold 1516 has a lot of followers and I use it most of the time, but I do like the Bosch filter that is the crossover part # for the NAPA.
Just as important as getting the old seal out of the block with the cannister is getting it out for the spin on adaptor as it seals in the same channel as the canister does.
Gliderman8
Yes PB... I was just kidding :cheers:
I have yet to change my oil. This is only the second season I've had my car on the road. I had it changed at the end of last season by a garage. I hear it is a messy proposition to change without the spin-on adaptor. I will have to add that to my wish list!
Thanks for the info.
AngliaGT
It's not that bad - don't remove the canister from
the car,just deal with it in the engine compartment.
There's also a hole in the fender to line up the
on the end of the canister with a socket.
- Doug
M_Pied_Lourd
Doug,
As an FYI, not all 6's have that hole.
Cheers,
Tush
A TR6 spin on oil filter for tr6 Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
M TR6 '72 TR6: Oil in Coolant Triumph 25
M Tr6 oil cooler - do need a thermostat n Texas? Triumph 3
D TR6 '74 TR6 Tune up, oil, filters questions Triumph 3
B TR6 TR6 High Oil Pressure Triumph 20
gbtr6 TR6 TR6 Oil Level, New Motor and Leak Triumph 16
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
D TR6 Tr6 oil pan Triumph 3
A TR6 TR6 Aluminum oil gallery plugs Triumph 4
Gerry M TR6 TR6 gear oil Triumph 8
B TR6 Oil in a grease gun for TR6 lower steering swivel? Triumph 16
sundown TR6 1973 tr6 oil pressure light Triumph 3
I TR6 75 TR6 Oil Pressure Switch replacement Triumph 16
T TR6 Will a 71 TR6 oil pan come off in the car? Triumph 3
sundown TR6 TR6 oil pressure Triumph 7
TRclassic3 TR6 TR6 Leaking oil gallery plug Triumph 5
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
RomanH TR6 '74 TR6 Oil Pressure switch Triumph 7
Woodie TR6 tr6 oil change Triumph 5
Mike_Roe TR6 Oil usage - TR6 Triumph 8
T TR6 TR6 oil loss/usage Triumph 28
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
B TR6 TR6 rear axle oil change Triumph 21
B TR6 TR6 Oil Cooler hoses Triumph 1
I TR6 TR6 oil sending unit thread size help please? Triumph 12
glemon TR6 TR250 TR6 no oil pressure after rebuild Triumph 20
W TR6 TR6 Timing chain oil seal question Triumph 3
hondo402000 TR6 TR6 71 Oil pressure gauge Triumph 3
mabbott TR6 73 TR6 oil pressure switch Triumph 4
I TR6 TR6 oil suggestions Triumph 9
B GT6 GT6 Oil Cooler Kit for TR6 Application Triumph 3
I TR6 What type of oil for TR6 rear shocks? Triumph 2
T TR6 TR6 Oil Pressure Triumph 49
S TR6 priming TR6 oil pump?! Triumph 18
Brosky TR6 3-Prong TR6 oil pressure switch Triumph 13
2wrench TR6 '74 TR6 Rebuild Latest...rust in oil pan Triumph 5
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
jjbunn TR6 Engine Oil Level Question - TR6 Triumph 12
hondo402000 TR6 TR6 plastic oil pressure line Triumph 2
P TR6 TR6 Oil Capacity? Triumph 7
I TR6 TR6 oil pressure information Triumph 7
A TR6 TR6 Oil Pan and head gasket leak??--help Triumph 4
F TR6 TR6 oil looks dirty soon after change... Triumph 6
F TR6 Need help w/TR6 oil cooler install... Triumph 16
hondo402000 TR6 OIL pressure gauge Needed 71 TR6 Triumph 10
