TR6 TR6 Hardtop Installation Guide please
jobster
I am a proud owner of a '73 TR6 PI just for month. A longtime wish finally fulfilled. Anyway, car came with a hardtop. PO never bothered to install it and most hardware missing. Have all the gear together now, and just finishing of installing a new rubber seal on the windshield side of the hardtop.
Now I am about to install the whole thing. I am totally confused on the rear end installation. The softtop is riveted. Do I need to undo that in order to find the plugs? Do I need to uninstall the softtop and -frame as well. Pictures or guides on the exact location of the side pillar-attachements would be helpfull as well since I think I need to unbolt the attachments for the windblocker as well.
Tx.
Gordo
Jobster,
The rear soft top rail must come off the car to access the rear bolt holes. You can leave the soft top assembly installed.
TRF has a guide available, but for what is's worth here is what I do:
a. Install distance piece (2) in windshield frame from the top.
b. Place hardtop on car and start front bolts, rear and side mounts.
c. Work your way aound gradually tightening all fasteners. DO NOT OVER TIGHTEN THE WINDSHIELD BOLTS. If you do, you'll end up with two bumps.
d. Roll up windows and close the doors. Adjust side and rear to obtain a good alignment.
The rear hardware will adjust the gap between the top and deck lid. You may want to leave a gap between the bumper and rear deck because if it touches, while you drive it will flex and leave marks in the paint which will require touch up in the spring.
Just out of curiosity, where did you source your windshield to top seal? I've gotten two from different sources and they did not fit at all. I want to install mine in a month or two and need a good seal.
Gordo
J
jobster
Gordo said:
Jobster,
Gordo
Got mine from Rimmer Bros in the UK. Looks like a good fit, on my hard top at least. Thanks for the info, 1 clarification, the rear soft top rail is the one that attaches the softtop t the body. In my case the buttons are all riveted.
TR4nut
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Thanks for the info, 1 clarification, the rear soft top rail is the one that attaches the softtop t the body. In my case the buttons are all riveted. [/QUOTE]
If I understand you, yes, the soft top and buttons are likely riveted to the soft top rail - but the rail itself is bolted to the body if I remember correctly.
Simply unbolt the rail, it will still be attached to the soft top.
Regards,
Randy
Gordo
There should be 5 bolts holding the rear stiffener to the car. The soft top is riveted to the stiffener with lift the dots so the tonneau and top cover can be installed.
Try partially stowing the soft top and look at the stiffener for the 5 bolts. If the 5 bolts are not there, then the top was installed incorrectly.
I'll try Rimmer next for the seal.
Thanks, Gordo
J
jobster
OK, will give it a shot. But 1st I need to figure out what the "clickerdeclack" is at the right rearwheel. Thought it might be the hub cap, since it missed 2 springs, but no. Oh well, never a dull moment.
D Wanted TR6 hardtop fraud/scam ALERT Triumph Classifieds 5
H Wanted Wanted TR6 Hardtop Triumph Classifieds 3
tr6nitjulius General TR TR6 Hardtop Time! Triumph 0
J For Sale TR6 hardtop glass Other British Classifieds 0
J TR6 TR6 Hardtop Hoist Triumph 2
J Wanted TR6 Hardtop Hoist Triumph Classifieds 1
E Wanted TR6 Hardtop Triumph Classifieds 0
Paulus TR6 TR6 Hardtop Instructions Triumph 4
Brinkerhoff TR6 value of a TR6 factory hardtop Triumph 5
7 TR6 help with tr6 hardtop value Triumph 5
John_Mc TR6 TR6 Hardtop on Bay Area Craigslist Triumph 0
F TR6 TR6 Hardtop Triumph 0
F TR6 TR6 HARDTOP GLASS [rear] Triumph 7
G TR6 Anyone looking for a TR6 Hardtop? Triumph 22
eschneider TR6 Steel TR6 hardtop....? Triumph 3
justin_mercier TR6 Journy to long island for a TR6 Hardtop Triumph 8
T TR6 tr6 factory hardtop pics needed Triumph 6
Geo Hahn TR6 TR6 Factory hardtop Triumph 11
T TR6 tr6 hardtop glass and trim Triumph 5
Brosky TR6 West Coast [WA] TR6 Hardtop - eBay - Triumph 1
Brosky TR6 Southern TR6 Hardtop, SC - eBay - Triumph 3
Brosky TR6 Interesting TR6 HardTop on eBay [East Coast, VA] Triumph 1
Brosky TR6 Sweet TR6 hardtop for the Louisiana boys Triumph 0
Brosky TR6 TR6 Hardtop for sale down south Triumph 2
Brosky TR6 TR6 Hardtop in Boston Triumph 20
V TR6 How do you mount a hardtop on a TR6 Triumph 15
V TR6 TR6 hardtop Triumph 15
G TR6 Hardtop-TR6 Triumph 2
bobh TR6 TR6 Factory Hardtop Install Instructions Triumph 7
bobh TR6 Factory Hardtop Instructions TR6 Triumph 0
C TR6 TR6 Hardtop Factory vs Aftermarket Triumph 11
MrPandy TR6 TR6 Hardtop question Triumph 12
padjo TR6 Hardtop for TR6 Triumph 3
V TR6 can you get a NEW TR6 hardtop? Triumph 6
Cain TR6 TR6 Hardtop Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
