TR6 TR6 fuel tank fitting size.
G
I went to the hardware store to get a 90 for the fuel line out the tank and it's not NPT. What is it? This is really becomming a headache. Main thing I need a brass 90 to screw into the tank. Where can I get one quickly?
hondo402000
its not a pipe thread, its a machine thread, not tapered, I belive there is a flaired tubing connection into the tank but I cannot help you with the thread size I would think its the same thread that goes into the fuel pump from the tank
Hondo
M_Pied_Lourd
Yes, there was a compression fitting on mine as well.
Cheers,
M. Pied Lourd
tr6_easyrider
I don't think you want a 90, not unless you have fuel injection.
More like this. And I think the tubing fits into the tank a little higher
than the bottom of the tank to keep any crude from passing into the line.
https://trf.zeni.net/TR6bluebook/23.php
I can't rebember if you install the tube before or after you
install the tank. I think before.
Fuel line out of the tank is 5/16
DNK
Check out the Rimmer page.It is a 90.
Stay tuned and I'll post what I just had made.
Think you like it Billy
DNK
2 choices Billy
1. Rimmer has the PI model tank outlet that is curved as the pump for those was in der boot.
Rimmer version
2.I had this built for my situation
G
I made a curved piece of tubing. It screws in o.k but I don't have enough room for it and believe me, I made it as tight a bend as possible and as close to the tank as possible.
DNK
That's what the guys who built mine said.
Can't bend it that tight.
Don't know if the Rimmer ones is tighter.
Mine works for location
DNK
Are you sure it isn't tighter.It is made for pretty close to your application.
E mail them and ask what the height of the bend is
G
Made it work. Tightened the bend a bit and added some clearance. Should be o.k now. bad weather moving in so I'm staying indoors.
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
A TR6 How many fuel filters-TR6 Triumph 25
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
