TR6 TR6 Fuel pump spares
vettedog72
Vendors and part numbers of tried and proven replacement parts are what I am seeking here because recent fuel pump discussions have me concerned. My TR6 (1974) has the OEM pump that works fine even after 80+k miles. However, my concern is that I know it will not last forever and a replacement or rebuild kit will be in order. In the past I read about pumps and rebuild kits with low quality if any quality at all were on the market. Also, I read that the OEM feed line and fitting were subject to problems if not R&R in some reasonable past time. The problems with the feed line were unusual fitting size, the pipe crushes when removed, etc. I will not replace my pump until it fails but I want to be prepared. Is there a particular pump or rebuild kit and feed line that I should keep on hand for insurance? If I remember correctly, the metal feed line, from the fuel pump, goes to a rubber hose where the inline fuel filter is located.
G
Don,
I have a new fuel pump coming in tomorrow from TRF that is supposedly built to the same specs and quality as the original AC pump, which has been out of production for almost 20 years. This new one is made in Italy (at least on the same side of the earth as UK) and is made using the same exact mould designs. Others have said that it is quite good. I'll install this week, will let you know although it may (I hope) be quite a while.
Bill
jerrybny
Moss sells a TR6 top quality replacement for $42. It even has the priming lever. That is what I have in my trunk as a spare.
G
I am using a 5/16" steel fuel line (original, I doubt it) that enters the pump and a 1/4" that exits. That said, the new pump came in today, along with a recipe for spaghetti sauce, and both the entry and exit holes look exactly the same. Hmmmmm. I will have to take my old one out to see if this will work or change a line. Not good. I have forgotten what the brass tightening nuts look like, I just remember that both are compression fittings. Surely there are two sized fittings that go into the different holes. Surely. Right, with my luck. Guess I will find out.
Bill
V
vettedog72
$42 can be a real life saver spare when you get very far from home. I look foward to when you have the new one sorted out.
G
My plan is to hopefully get the new one installed and running and to re-re-rebuild the OE fuel pump.
As a spare for long trips.
Bill
G
Now I have to look through my pile of spare parts to find some new compression fittings. I have been told by an old hand that the type of compression fitting to be used in a fuel pump line is different than the hardware store variety compression fitting, although they look exactly the same. Can anyone comment on this.
Never, never reuse a compression fitting.
Bill
G
I got the "Italian Job" fuel pump installed this morning and it seems to work ok. Time will tell.
Bill
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
padjo TR6 TR6 Fuel Pump Triumph 1
A TR6 How many fuel filters-TR6 Triumph 25
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
71tr TR6 fuel line TR6 Triumph 6
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
