TR6 TR6 fuel lines.
DNK
I want to make sure I have this right. The line from the tank to the pump is 5/16.
The line from the pump to the carbs is 1/4.
Would it matter in my case. The Carter electric pump is in the spare tire well and it is a long way to the carbs.
R
RonMacPherson
the larger diameter fuel line, obviously will flow more volume of fuel. So I recommend staying with the larger diameter line/hose as far forward as you can...
DNK
DNK
Will it cause to much fuel pressure or amount to the carbs? (SU's)
Brosky
It will be based on the pump's pressure output. If that is OK, you should be fine.
T
Tinster
Don, I've got 5/16 from tank to pump, out of pump
and into a 1/4" Tee just before the front carb.
My fuel pressure checked out good with either
mechanical or elec pump.
d
DNK
DNK
So do you guys think that 5/16 up to the carbs and then Y and then 1/4 should be OK?
Next question. My 5/16 line is pretty fat, .572. It's fuel/emission line rated to 50 psi. Is it possible to get thinner line?
T
Tinster
Don,
My 5/16" ID hoses are fairly chubby OD also.
But when you live on island with only
a choice of one.............chubby is ok.
Also, I think chubby is a good thing for inside
the engine compartment. More insulation to keep
the fuel cooler going into the carbs.
d
TR6BILL
Don, the stock mechanical fuel pump accepts only 5/16" going in and 1/4" going out. Stick with this.
R
RonMacPherson
Don, the size of the fuel line is not going to affect the fuel pressure. It is not like the nozzle on a water hose where you can turn it down and see, what seems to be an increase in pressure.
It will have an affect on the VOLUME of fuel transported. Read that the amount of fuel sent from one site to the next.... Pressure is dependent on what's pushing it, gravity, weight on top of the fuel(bladder) pump, etc...
DNK
DNK
Bill-So are you saying stick with the stock size or the pump.?
Ron- Understand that, concerned ,will the volume overwhelm the carbs ?
T
Tinster
<span style="color: #660000">Hi Bill !! Strange?
I have a Brosky rebuilt OEM mechanical pump in
my TR6 and both inflow and outflow are
5/16" pipes going into 5/16" hoses.
d</span>
TR6BILL
Both. You only need about 2-3lbs of pressure.
TR6BILL
d</span>
Dale, that is your problem. Brosky rebuilt your pump! Should be as I stated above. Don't question me!!
T
Tinster
Not to argue with an Expert Bill..........
because I know just about nothing of auto mechanics
but....
I've had 5 or 6 mechanical pumps in my car:
OEM, rebuilt OEM and new manufacture mechanical.
Every single one had the same steel pipe size flowing
in and flowing out. All the pipes slid perfectly into
5/16" fuel line hoses.
But then, my car was so Pedro-ized when I got it
so who knows?
I've got Paul's pump doing a so very fine job with
5/16" necking down into 1/4" at the carbs.
No flooding of my carbs and enought fuel to easily
hold 80 mph.
<span style="color: #006600">EDIT: I've a hard wired electric pump in the engine bay
as emergency backup for when the mechanical fails.
I checked it- 5/16" hoses in and out. Strange.</span>d
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Dale, that is your problem. Brosky rebuilt your pump! Should be as I stated above. Don't question me!![/QUOTE]
Hey, what's up with the questioning of my finely rebuilt fuel pumps. And here's a few pics to prove the inlet & outlet sizes.
T
Tinster
And here are photos of Paul's pump
installed in my car.
Thanks again, Paul!!
d
DNK
DNK
Dale- The pump probably has 3/8's pipe thread on both sides and you can size it any way you want.
R
RonMacPherson
Don, the volume will not overwhelm the carburetors. The flow of gas, both volume and pressure is controlled by the needle and seats. All the volume in the world at low pressure is fine. Excess pressure is what overcomes the needle and seat...(or dirt, or foreign matter, jamming the needle open).
DNK
DNK
Cool, thanks Ron.
Now, anybody know of skinnier tubing w/o going to metal?
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Now, anybody know of skinnier tubing w/o going to metal?[/QUOTE]
That's resistant to the fuel and additives of today, while going around and over a hot metal block?
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 fuel lines for 69 TR6 Triumph 3
A TR6 How many fuel filters-TR6 Triumph 25
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
G TR6 TR6 Fuel Injection ? Triumph 8
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
I TR6 Fuel injection for TR6 Triumph 4
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
Tullamore TR6 TR6 Fuel Leak Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
