TR6 TR6 Fuel Injection ?
GilsTR
We are still taking the 72 TR6 apart...and making pretty good
progress. Today I ran into a TR6 owner from Tahoe that had
installed a PAtton Machine fuel injection system in his 74
TR6. Any feedback from the forum re this system? Any other
FI systems that we should be considering? Thanks, Gil
davidk
I've had it on my TR-6 for over two years. It's worked well, and I haven't had to replace any parts yet, including the cap, rotor and spark plugs. Always starts right up and is ready to go. Takes a few programing changes to get it 'dialed in' initially, but then it's good to go. It's interesting to hook it up to the laptop going down the road and seeing how the engine is performing. Rick has been great to work with and is very supportive. I'm in the middle of replacing the engine (non original high mileage engine with nearly no oil pressure), so I'll probably need to have the program checked to be sure its doing as well as it can. I reworked the wiring harness to keep it hidden. There are more sophisticated systems out there, but this is a more basic system that works very well. Here's a picture of the old engine:
tdskip
Gil - if you are really serious about this let us know. This topic comes up from time to time and I'm kind of itching to give it a try as well. Maybe we could get a couple of use together and do a virtual group build to help one-another through it?
DNK
Is in the plans and that's 1 reason I want to pull the tank. To prepare it for that.
G
GilsTR
Thanks guys for the replies.
TDSKIP excellent to Bob Daniels web site! Lots of helpful info there!
We are in NorCalif...so probably won't work to pull together
a project together with anyone else...but you never know.
Probably 6 month away from starting this as car is still coming apart. Gotta say the idea of the F I is got the wheels turning! Gil
tdskip
Hi Gil - yeah, knew you where up North (relatively speaking anyway). Thought we could document our steps/progress here and augment Bob's write ups but no biggie either way.
BobbyD
I've had Rick Patton's TBI conversion in my car since '05/06 and I haven't touched anything.........not the timing or the plugs or anything! It starts right up regardless of temperature and idles and runs smoothly. It pulls to the redline with no problem. No stumbles, hesitations or backfires and it gets GREAT gas mileage. The key to this install is following directions! Sounds simple but the people who have had problems are the ones who bought the kit and handed it off to the "pro" to install.........I don't need no stinkin directions........ :nonod:
My whole installation is well documented on my site. :driving:
G
GilsTR
TD SKIP...Would be happy to post when we are ready to start the project...you are right...would be good to compare notes
as the projects go along! Gil
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
I TR6 Fuel injection for TR6 Triumph 4
Morris TR6 TR6 Fuel Injection Triumph 21
A TR6 How many fuel filters-TR6 Triumph 25
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
F TR6 TR6 Fuel Pump Priming Triumph 11
sundown TR6 1973 TR6 fuel pump Triumph 4
B TR6 TR6 Fuel Filter keeps clogging Triumph 9
Gliderman8 TR6 Mounting location for electric fuel pump on TR6 Triumph 42
D TR6 1976 TR6 Fuel Lines Triumph 7
I TR6 75 TR6 Fuel sending unit gasket Triumph 1
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
G TR6 TR6 fuel tank fitting size. Triumph 14
Gliderman8 TR6 Troubleshoot a TR6 Fuel gauge problem Triumph 36
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
M TR6 TR6 Fuel Delivery Issue Triumph 18
I TR6 TR6 fuel pipe nut source? Triumph 5
I TR6 TR6 fuel pump - how do I replace these? Triumph 18
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
wangdango TR6 76 TR6 electric fuel pump? Triumph 3
T TR6 tr6 fuel sending unit Triumph 5
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
BobbyD TR6 TR6 Fuel Pump Triumph 1
Brosky TR6 Fuel Pump Kit for TR6 Triumph 3
Gliderman8 TR6 TR6 Fuel electric pump? Triumph 14
DNK TR6 TR6 fuel lines. Triumph 20
B TR6 TR6 Fuel Odor in the Brake Servo Triumph 7
B TR6 71 TR6 Fuel Tank firewall? Triumph 6
J TR6 Just another whining TR6 fuel pump again? Triumph 19
SCguy TR6 How can you tell if your TR6 fuel pump is working? Triumph 4
I TR6 TR6 Fuel gauge help Triumph 7
E TR6 TR6 Fuel / Mixture ? Triumph 4
71tr TR6 fuel line TR6 Triumph 2
V TR6 Oil and Fuel for TR6 Triumph 6
G TR6 Free OE TR6 Fuel Pump.....................8 bucks. Triumph 2
71tr TR6 fuel line TR6 Triumph 6
V TR6 TR6 Fuel pump spares Triumph 8
F TR6 Changing TR6 fuel tank sending unit... Triumph 6
T TR6 Repair or replace TR6 fuel level sender unit Triumph 4
G TR6 Fuel sender resistance for TR6 Triumph 1
I TR6 fuel lines for 69 TR6 Triumph 3
Tullamore TR6 TR6 Fuel Leak Triumph 4
padjo TR6 TR6 Fuel Pump Triumph 1
M TR6 TR6 FUEL TANK VENT PIPE Triumph 3
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
