TR6 TR6 EFI Conversion
iani
I have just finished converting my '69 TR6 to EFI. I have fitted an Emerald K6 ECU, triple Jenvey Heritage Throttle Bodies on a Racestorations DCOE manifold. The engine is a saloon block with a lightened & balanced rotating assembly, bored out to +30. The cylinder head is a Fast Road spec' from Peter Burgess and the cam is a PH2 from Newman. The car went on the Rolling Road at Emerald on Friday and produced 178.9bhp, I was very pleased with that.
Ian
Gliderman8
Nice!
Gliderman8
What are your thoughts of adding EFI to stock TR6 engine?
Would there be any benefit?
I
iani
You would get much improved starting and improved MPG I would expect, on a US spec' car there is always the Pattonmachine injection conversion you could do.
LarryK
Exactly what I'm looking for to put on my 3.4 MK1 Jag. Have seen these on the TRs, and one on a Jag, looks exactly like the multiple carb engines.
M_Pied_Lourd
Yeah, love it.
Cheers
Tush
DNK
Very simple solution
You can adpt this to Patton's system
Andy Blackley
Don:
You installed the O2 sensors on the header branches from the outer cylinders, 1 & 6. I think I know the reasoning, but please explain.
And also curious to know how you dealt with crankcase ventilation.
Andy
DNK
The 2 ITB's feed 1-3 and 2-6 respectively
The 2 tubes in front were the easiest.
Crankcase ventilation?..., same way the stock did it
DNK
Standard off the shelf
Don't think the company is in business anymore
DNK
I looked it up
the name is up for sale on line
Extrudabody
rooster
Thanks. They were mainly ITB's Looks like it was a small operation running out of a guy's garage (or something like that). Stopped in about 2017. Lots of photo's in google.
martx-5
When I was considering EFI for my TR3, I was looking at these throttle bodies from Borla Induction. As it turned out, I got the original SUs dialed in so good with a wide band O2 sensor that I abandoned the EFI project. I have a bunch of new stuff that I accumulated from that project such as fuel pump, MegaSquirt (w/wiring harness), temp sensors, and MAP sensor if anyone is interested...very reasonably priced.
https://www.borlainduction.com/2700-series.html
DNK
Yes, I was going to run those off the Patton Computer set up
A TR6 TR6 EFI - where do I start? Triumph 26
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale β€˜74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale β€˜74 TR6 original radio Triumph Classifieds 0
EWD For Sale β€˜74 TR6 original starter Triumph Classifieds 0
EWD For Sale β€˜74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 β€˜74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
T TR6 TR6 Tire Pressures Triumph 2
