TR6 TR6 Door Glass
RonR
Folks,
I am looking for some advice to help a friend with his TR6.
He cannot get the door windows to mate up with the top and windshield. At one side, the glass stops about an inch short of the top.
At other side, the glass is not parallel with the windshield, having a gap between the glass and top of the windshield of around 1/4 inch and around 3/4 inch at the bottom.
Any advise you could off would be appreciated.
Thanks.
Ron
pdplot
1. Remove the door panels. Use a screwdriver and an ice pick or a nail to drive out the metal pieces holding the handles to the shafts.
2. The glass should fit squarely and snugly in the lift channel. Run the windows up and down to see what the problem is. It should be obvious.
3. While you're in there, squirt some oil on the mechanism to make it work smoothly. It may be tight - my driver side is but the passenger side is looser.
4. Some of the real experts on this Forum could give you more detailed advice but without taking the panel off, you won't be able to find and fix the problem. Hope this helps.
charleyf
Very often the fitting of the window with the windshield is the problem with the windshield being incorrectly fitted. Use the windows to position the windshield . You will need to loosen the posts at the bottom of the windshield and likely the fasteners at front and center of the dash . While windshield is loose raise the windows on each side to get the correct angle for the windshield.
A second note is that the base of the windshield fastener has both a nut on the end plus a bracket that is bolted to the body. To change the angle of the windshield those need to be loosened.
M_Pied_Lourd
There is also a little stop inside the door frame that limits the up and down travel of the window. It is secured with 2 set screws. These need to be loosened to adjust the stop.
Cheers,
Tush
glemon
It is kind of a distant memory, but I know my windows didn't line up well with the windshield when I did my TR250. I recall adjusting the windshield to get the angle and gap right.
R Wanted TR6 Interior Door panels Triumph Classifieds 0
Sarastro TR4/4A Puzzled about TR6 door seals on a TR4A Triumph 7
sundown TR6 1973 TR6 door check straps Triumph 3
B TR6 How restore the "gold" finish of TR6 door latch? Triumph 4
B TR6 TR6 door latch challenges Triumph 0
I TR6 Help installing TR6 door pulls and fuzzy seals Triumph 14
G TR6 TR6 door rattles/weather stripping Triumph 0
G TR6 TR6 innner door release and window crank removal Triumph 5
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
TR6oldtimer TR6 TR6 door and fender Triumph 12
TR6oldtimer TR6 TR6 Door Stop Triumph 3
hondo402000 TR6 TR6 New door switches Triumph 1
hondo402000 TR6 TR6 Door Switches Triumph 19
M TR6 tr4-tr6 door switches Triumph 3
floyd TR6 TR6 door rattles Triumph 8
hondo402000 TR6 TR6 Door Catch plate Gasket Triumph 6
Gliderman8 TR6 '73 TR6 Door Pulls Triumph 9
71tr TR6 TR4 door handles on a TR6 Triumph 4
T TR6 Let's talk TR6 door gaps! Triumph 20
bcbennett TR6 TR6 Door adjustment...possible? Triumph 1
N TR6 TR6 Passenger door and window fit ? Triumph 5
J TR6 Door gaps on a tr6 Triumph 5
2wrench TR6 Help removing an exterior door lock, '74 TR6 Triumph 1
N TR6 TR6 Door hinges Triumph 1
B TR6 TR6 door window alignment question Triumph 7
TR6oldtimer TR6 TR6 Optimum door gaps? Triumph 13
D TR6 Door Latch 1972 TR6 Triumph 1
J TR6 how do you remove the door key locks on a tr6? Triumph 2
I TR6 TR6 window door pull/window seal help Triumph 6
O TR6 '73 TR6 Left Hand Door Switch Triumph 3
Got_All_4 TR6 TEX DOOR MIRROR VS BULLET MIRROR TR6 Triumph 22
TR6oldtimer TR6 TR6 door bottom sticking out Triumph 2
D TR6 70 TR6 Vent Door Spring Triumph 1
I TR6 Removing door check arm in TR6 Triumph 6
Paulus TR6 TR6 Door Panels Triumph 5
AltaKnight TR6 TR6 door fix Triumph 5
John_Mc TR6 TR6 door jam switch Triumph 5
H TR6 TR6 Door seal Furflex Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
