hondo402000
I purchased 2 gaskets that go behind the door catch plate, scanned it into my computer and printed it out and its identical in size, so you could make your own from gasket material, here is the file if you want to make some, after posting I will open the file print and check the size to see if correct note it works, make sure it prints 100 percent size and not larger
