TR6 TR6 Differential Inner Shaft Seals
Aeroken
In the process of preparing my TR6 for the diff mount repair, I found the differential seals leaking pretty significantly. After careful consideration (and determining that I have an early model diff with the solid spacer), I was able to fairly easily replace the pinion seal.
Now I'm going after the inner shaft seals. The shaft assembly came off the diff pretty easily and I removed the big nyloc nut and washer, but the drive flange won't let go of the shaft. I've tried heat and "gentle percussive persuasion", but it won't come off. Is a press typically needed to do this (Bentley just says "withdraw the flange, key, and oil seal), or should I just soak it in penetrant and try again?
Ken
swift6
Don't you just love it when the Bentley makes something sound so easy. /ubbthreads/images/graemlins/rolleyes.gif
You need a press and some not so gentle hydraulic persuasion.
trboost
Ken,
There's no way you can seperate the axle from the flange by hand or puller. You need to bring it to a shop with a 20 ton press. Make sure they support the flange properly or it will distort.
To assemble you only need to slide together & torque the nut to spec.
Aeroken
Aeroken
Thanks for the advice! I initially thought a press would be required but Bentley led me down the easy path so I tried anyway. Also, what is the torque spec for the nut? Bentley does not list one.
Thanks again!
Ken
TR6oldtimer
I'm in the process of doing this as well. First go to a really good machine shop. Otherwise you will be looking for a replacement hub.
Bently on pg 06.3 sets the torque for a 5/8 nf bolt at 90-120
While I'm at it, I will be replacing the the axle bearing.
Any comments on a good supplier? The better known TR parts houses price these bearings from 29-75 dollars. The $75 is for
SKF or NTN. The lower priced bearings do not have a listed manufacturer.
Aeroken
Aeroken
The machine shop did the trick although his quote was "man, that was hard!". When it did not initially come right off, he even pulled a Bentley manual from the shelf and verified the procedure! The flange is not distorted and he even cleaned everything up nicely.
Anyway, I put everything back together tonight and no leaks so far. I did notice that there seems to be a slightly larger gap (maybe 1/16 or slightly more) between seal housing and the flange "stone guard" on the one side I've done. I measured from the housing to the flange on both sides and it is virtually identical. The slight step under the washer (between the shaft and the flange) looks the same as before and the same number of threads are showing outside of the nut so the flange seems to have gone back on the shaft OK. I did not disturb the bearing on the shaft so that spacing didn't change. Should I be worried about crud getting in there if I run it as it is or is there something else I should do?
Also, thanks for the tip on the torque chart up front in the Bentley manual, I'd never noticed that. I just saw the random torque listings in some procedures.
Thanks again!
Ken
TR6oldtimer
I have almost completed reassembling the rear inner axle and noticed the same increase in the gap between the hub and oil seal flange. I too was worried about this, but not from getting junk into the gap but concerned about the seal riding on a sufficient amount of the hub to do it's job. I determined the seal did have enough metal to ride on, so I was going to let it go. After your post, I took quick look at the axles on a TR250 dif I have and it was immediately apparent to me as to what was the problem. Seems they did not seat the bearing all the way down on the axle shaft. There is about a 1/16 inch gab between the bearing and the seat. As there is minimal wear on the hub, I will be tapping the bearing back out toward the hub to close the gap.
Oh, by the way, the question on $30 vs. $75 bearings was settled to my satisfaction. I bought the $30 bearings, which turned out to be made in England by RHP, a British company formed by the union of three bearing mfg's including Hoffmann, the original maker of the axle bearings.
Aeroken
Aeroken
I was initially concerned about where the seal was riding also, but I double checked and it seems fine. The bearing is properly positioned and was not disturbed. I think what happened is the that the stone guard got bent towards the flange during the press work because it looks much flatter than the un-worked side. That is the only thing that looks really different between the two sides. I was able to bend it back towards the seal and it looks quite a bit better now, but it appears that part of the tack weld that holds it on has broken loose. While I usually hate JB Weld, this seems like it might be a good place to use a bit to make sure the stone guard stays secure and can't foul the seal/housing. Thoughts?
Ken
TR6oldtimer
Ken,
The shaft does not rotate at a high rpm, nor is there any stress, but I would take it in and have it welded or brazed for peace of mind. The machine shop I use has the necessary equipment for light welding or brazing jobs. You might want to check with your shop, after all they bent it, to see if they can do it before going to a welding shop. A little humble pie on their part might save you a couple of bucks.
Noelan
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
J TR6 TR6 Differential Rebuild question Triumph 6
L Wanted Tr6 differential Triumph Classifieds 9
B TR6 TR6 Differential Followup, and inspection questions. How do you know it's good? Triumph 2
B TR6 TR6 Differential bearings. Triumph 3
T TR6 TR6 Differential Ratios Triumph 8
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
SkinnedKnuckles TR6 TR6 Differential Rebuild Triumph 4
glemon TR6 tr6 differential seal Triumph 10
W TR6 TR6 Differential Question. Triumph 6
MTribe TR6 TR6 differential leak fix - what to do? Triumph 11
mgedit TR6 TR6 Differential Mounts Triumph 6
K TR6 tr6 differential - need feedback! Triumph 16
J TR6 Last TR6 differential question Triumph 16
R TR6 TR6 differential internal upgrade Triumph 0
H TR6 Tr6 differential backlash Triumph 2
T TR6 What year TR6 did NOT have a differential oil drai Triumph 11
C TR6 TR6 Differential Oil Seal ? Triumph 0
tr6web TR6 DIfferential and support damage TR6 Triumph 20
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
