TR6 TR6 dash refinishing
ichthos
Well, I can put up with freezing temperatures and no top, but with record rainfall, I have to accept the fact that I will need to park my TR6 and do the work I have been putting off. I repaired my dash and am getting ready to put a finish back on. My questions is what type of finish was originally on the dash? If this finish is not available, what are some suggestions for something that will hold up to the elements? I thought about spraying laquer, but is there something better? Also, what kind of paint/color was originally used to paint the edges? Thanks for the suggestions in advance.
Kevin
DNK
Kevin- The school kids must have you hopping this year. Thought you dropped of the face of the earth.
trrdster2000
If you want to go back to the orginal then that would be teak and since you have all winter go with the hand rub poly from Minwax and after about 3 coats use some 0000 steel wool to buff it off, tack cloth and start adding coats and steel wooling until you get your desired gloss. You can get in 3 coats in a day if it's in a warm area. One word of caution, go lightly around holes or you will take off the finish on the edge. Wayne
TheAssociate
No kidding, Kevin! The rain has been unbelieveable! I'm just across the water in Victoria B.C.
Adam H.
____________________________________________________________
1972 Triumph Spitfire.
I
ichthos
Yes, Don, those little fifth graders have been keeping me busy (and exhausted). The main reason I was not on the forum though is because I have been busy driving instead of working. I will drive anytime day or night as long as it is not raining (top not installed yet). I was also getting too obsessed working on the TR6. I needed the break.
As far as the two finishes recommended, do they both fill the grain like the origninal finish? I was lucky enough to get a NOS glove box door on Ebay that actually matches the grain on my dash (the old one was destroyed when I bought my car.) The new door has the orginal type finish. I was going to just match up the color and then put a satin finish on the rest of the dash to match. Any other suggestions?
Kevin
I
ichthos
Tom, thanks for the info. I did check your website out. The dash you did looks great, but I couldn't tell how well the grain was filled in. I still have some questions, so I'll contact you through your website.
Kevin
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Thickness of original TR6 dash Triumph 2
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
rjc157 For Sale 74 tr6 dash Triumph Classifieds 2
S TR6 TR6 Dash refinish: a nice surprise Triumph 4
S TR6 Removing TR6 dash [and suggestions on refinish] Triumph 12
TR4nut TR6 TR6 under dash pics? Anybody? Triumph 9
J TR6 TR6 Dash knobs Triumph 2
JimTR4 TR6 TR6 dash support in a TR4? Triumph 23
G TR6 TR6 dash and windshield frame removal Triumph 13
Coyote1 TR6 TR6 Dash Support won't go in Triumph 9
Tr4dude TR6 Tr6 resto dash Latest Triumph 3
V TR6 TR6 Center Dash Support Triumph 16
C TR6 TR6 Dash replacement, now only the horn works Triumph 6
S TR6 TR6 Dash Triumph 18
G TR6 Dash support options for TR6 Triumph 8
Brosky TR6 Free dash panel, late TR6 Triumph 4
G TR6 TR6 original dash bulbs as bright as newer bulbs Triumph 1
G TR6 TR6 dash lights not bright enough Triumph 22
mrv8q TR6 In the dash, '74 TR6 Triumph 2
I TR6 Veneer sanding, TR6 dash Triumph 3
C TR6 TR6 Dash Support Triumph 5
M TR6 TR6 dash Triumph 13
hondo402000 TR6 Veneering a TR6 dash Triumph 15
hondo402000 TR6 need a used dash for 71 TR6 Triumph 1
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
I TR6 TR6 dash help Triumph 8
I TR6 TR6 Dash help Triumph 7
I TR6 Reveneering TR6 Dash Triumph 3
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
B TR6 Installing a new dash in TR6 Triumph 38
2wrench TR6 How do I remove the rheostat from dash of TR6? Triumph 23
2wrench TR6 Need replacement bulbs ID'd for under dash '74 TR6 Triumph 4
roofman TR6 72 TR6 dash lite reostat question Triumph 10
F TR6 Looking for TR6 metal dash support Triumph 4
R6MGS TR6 TR6 Under Dash panel?? and dash cap Triumph 10
J TR6 TR6 DASH HELP? Triumph 6
G TR6 tr6 - really dumb dash question Triumph 4
nathandarby67 TR6 TR6 Dash on ebay Triumph 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 0
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 20
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
