Cain
I'm trying to set the timing on my TR6. What's the easiest way to turn the crank when doing static timing? The first time I set it, I didn't have the fan on the engine yet and I could turn the crank with a wrench. I really don't want to remove the fan to do that again. I thought about putting the car in gear and rolling it, but it's only me and I don't want it to get away from me.
A question about the retard unit. I assume this is the thing on the right side of the distributor with the vacuum hose on it. (I have a late '71 TR6 distributor number 41352 so it has a retard unit, but no vacuum advance.) If the retard unit is not hooked up to the carb, will this increase the idle RPM? I've never had the vacuum hose hooked up to the carb because the hose fitting to hook to the carb is non-existant - the hose burned in half before I got the car. The only way I've found to be able to keep my car going is with a high idle (around 1300 RPM),and I wonder that if the vacuum hose was hooked up correctly that the idle wouldn't be so high.
I need to get a new vacuum hose for the retard unit, but when I do where does it hook to the carb? (I have stock dual ZS carbs.) I don't see where a hose fitting would fit on the carb. Also, do I hook it to the front carb or the rear carb?
While I'm at it, what is centrifugal advance? I assume that this is timing advance that occurs when the distributor is in operation. The faster it spins, the further it advances.
Thanks for your help.
