TR6 TR6 Clutch knocking noise problem [not mine] *DELETED*
Re: TR6 Clutch knocking noise problem [not mine]
My MGA made a similar noise when the release bearing wore down and needed to be adjusted...The MGA has an throw adjustment on the M/C that allows you to correct this. I don't see anything like that on my TR6 M/C but maybe it has it somewhere else? I know his release bearing is not worn, but maybe it's the fork travel distance is not adjusted properly for his new setup.
There is no adjustment, but the placement of the rod is critical. I will ask him about that position. Thanks....
