TR6 TR6 Clutch Attachment Bolts (Clutch Assembly to Flywheel)
Rocky_LC
I am renewing the attachment bolts on my clutch assembly. These are the ones that attach the clutch assy/pressure plate to the flywheel (6 bolts).
I know they are 5/16” UNF.
Is there anything special about them? Can I just use grade 8 bolts?
Thanks -
Rocky
Thanks -
Rocky
Make sure they are correct length. Never to long..
Best if they have a nonthreaded shank.
Charley
Charley
I got to thinking more on this and wanted to correct myself. Because the clutch plate is so thin you may not be able to find a short enough nonthreaded shank. Therefore a threaded shank is okay. Still grade 8.
Charley
Thanks, Charley -
That’s what I’m going to use. Clutch & trans should go in shortly.
You are right, difficult to find shanked ones, and the original GKN bolts were unshackled.
Rocky
PS…. Documentation I found on line says the bolts are 5/16” UNF (24 pitch), but I found that my stock bolts are 5/16” UNC (18 pitch).
