TR6 TR6 Bolt?
PanP
Hello, I caught the English car bug a little while back and purchased a 73 tr6. The car had been sitting for many years(but, absolutely no rust) so needed some attention. When I was done replacing the majority of the front suspension I found this bolt on the ground. Do not know where it came from or if it is even from the tr6. Does anybody recognize it? I only ask because, from my extensive restoration of early 67-69 Camaro's I can identify any nut or bolt. Thanks for any help. IMG_4524.jpgIMG_4523.jpg
mallard
Don't think it came from the 6
poolboy
Whatever it is it looks like it went into a spire nut or maybe a captive nut.
There are a lot of spire nuts along the fenders, but the original bolts for those spire nuts had plain washers...maybe that one was used as a replacement.
P
PanP
That's what I originally thought, fender bolt, but have not found any missing. Thanks for your help poolboy.
tdskip
Not a TR stock front suspension bolt, for anything on the front end. After all these years lots of random things end up on our cars so not a huge shock to find things like this, bit nothing to worry about?
P TR6 Tr6 stromberg carb gas leak from starter valve bolt shaft Triumph 5
kurts100 TR6 TR6 Trunnion/Lower A-Arm Bolt--Torque or End Float Triumph 8
B TR6 Tightening crank pulley bolt on TR6 Triumph 2
B TR6 Removal of TR6 crankshaft end bolt! MANY THANKS! Triumph 3
B TR6 Help with removal of TR6 crankshaft end bolt! Triumph 11
M TR6 TR6 Trunnion Bolt Removal Triumph 3
V TR6 TR6 Crank pully bolt removal Triumph 8
T TR6 Bolt size/thread count for fuel sender TR4/TR6 Triumph 16
Brosky TR6 Up-date to Bolt On 72 amp Alternator for TR6 Triumph 35
Brosky TR6 Fiesta Bosch Bolt on TR6 Alternator Triumph 35
N TR6 Bolt size for TR6 Drive shaft? Triumph 6
A TR6 TR6 rear main seal housing special bolt ?? Triumph 1
G TR6 Crank Bolt Torque Setting on Aluminum Flywheel-TR6 Triumph 17
A TR6 Up-grade to 1/2" lug bolt, which ones??[tr6] Triumph 7
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
