TR6 TR6 "B" Pillar seal installation
bailee2
During my restoration I replaced the fuzzy door seals and they ended at the dash (about to the top of the door panel on both sides).
My question is should they continue up to the top of the windscreen as my friends TR250 does. Or does the fuzzy seal end and the "B" pillar seal began and runup to the top of the windscreen.
If so, how is it glued to the windscreen frame? How does it lay etc;
I cannot seem to find any documentation on this application.
I would appreciate any help.
I am down to small details such as this!!!
Thanks in advance.
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Re: TR6 "A" Pilar seal installation
Bailee 2, go all the way up to and under the alumimum top plate on the windshield frame and there is also a seal that goes on the face for the window to seal in the front, Moss #680-485, which you seem to already have. They are glued on first before putting the fuzzy seal on. Regular 3M rubber seal will work just fine.
Wayne
The fuzzy seals should go in as one piece, from the B-pillar aluminum car, down, forward, up to the top of the windshield, under the aluminum cap there. They really don't require gluing in, the metal clip inside them is enough to hold them in place. There is an occasion when you might want to remove them.
