TR6 Tr6 1974 Distributor
Wike
Should the cam on the distributor have movement side to side as well as up and down? When trying to set the points the cam always seems to move or float off of the high spot because of this play in the cam.
Roger
Bronze
No, it shouldn't have side-to-side play. Don't know much about the distributors fitted to TR6s, but some you can re-bush.
The side to side movement is probably from the plate being worn. Look at where the inside ring is and watch it as you put pressure on it, I bet the plate will rock. I have pulled the plate out and hammered the ring down some to make it not rock. Be careful if you do this. To much and the plate will no slide for timing advance. Put a pertronix ignition in and you won't have to worry about it.
Marv
tdskip
Welcome!
Might be time to send it to Jeff at Advanced Distributor. He does a lot of work for the folks here and really knows is stuff.
Gliderman8
tdskip said:
Welcome!
:iagree: Jeff is FAST and the work is SUPERB :iagree:
W
Wike
Thanks Marv,
I am very new, but totally enthused at this car restoring project. My question is: Where do I go to purchase the petronix,....is it just a conversion kit or whole new unit? If just a conversion kit, will my original problem with the distributor cam movemen still need to be addressed?
Thanks,
Wike
poolboy
It's alway better to have your equipment in good condition.
The Pertronix Ignitor is less sensitive to a worn out distributor than points.
Pertronix makes both a complete distributor and the Ignitor which replaces the points and condensor in a conventional distributor.
As to where to purchase it, I believe that all the usual part suppliers for our cars have them for sale. Sometimes you'll even catch a special price.
I hesitate to start naming names for fear of leaving out the very one that might have the best price.
Brosky
I would still have it checked and have the bushings replace by Jeff. He can install the Pertronix unit and make you a drop in points replacement plate that is all setup in case you ever want to go back. You can see that on my site here: Distributor Rebuild by Jeff
And ask to get the adjustable timing wheel as shown here: Adjustable Distributor Wheel
G TR6 1974 TR6 distributor advance spring specs Triumph 6
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
A For Sale 1974 TR6 Triumph Classifieds 1
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
H TR6 1974 tr6 allison xr700 Triumph 12
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
L TR6 1974 Tr6 ignition switch Triumph 3
T TR6 ajustable training arm brackets--- 1974 TR6 Triumph 14
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
Gerry M TR6 1974 TR6 Wheel lug torque Triumph 4
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
TR6BobNF TR6 1974 O/D TR6 For Sale in Newfoundland Triumph 1
I TR6 1974 tr6 Triumph 2
RynoBoy74tr6 TR6 1974 TR6 clutch adjustment Triumph 11
T TR6 1974 TR6 coil question Triumph 3
N TR6 need the carb mounting stud size for 1974 TR6 Triumph 14
2wrench TR6 Which water pump for my April 1974 TR6 Triumph 3
2wrench TR6 1974 TR6 Engine Rebuild and/or Repair Triumph 26
2wrench TR6 1974 TR6 heater hoses to firewall or bulkhead. Triumph 12
T TR6 Swapping 1974 TR6 fenders on to my 71 TR6? Triumph 5
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
