TR4/4A TR4A wire wheel tire size & powder coating?
tdskip
What do you say here guys on tire size? Suggestions on where to source the inner rubber band? Is the inner rubber band needed as on MGB wire wheels - I'd think so since the principles are the same, no?
Any issue with powder coating the rims after the spokes have been checked?
RJS
Interesting, this is one of the top projects on my list for 2010, new tires for the TR4A. Right now I am running 205/70-15s installed on 15x4.5 60 spoke wires. The tires probably timed out after 9 years and this is why I want to replace them. Even though I never had an issue with the 205's being too wide, most of my research indicated this width is too much for the 4.5 rim.
To maintain the stock diameter for speedometer accuracy, these combos are pretty good
165/80-15 (Kumho, Nexen and Vredestein, try easytire.com)
175/75-15 (cannot locate any in this size)
185/70-15 (this is my first choice in size and can only find the Vredestein)
195/65-15 (cannot locate any in this size)
I am pretty much decided to go with the 165's as replacements for a few reasons: best fit on 4.5" rim, cost, I am mostly a weekend cruiser not seeking max grip, curious to see if steering response is faster and car may be more "toss-able" with the narrower tires.
Yes you need the bands. Also, I have used Eastwood Detail Silver for wire wheels and it held up amazingly well. I plan to use it again. Re the powder coating, I recently read some posts here about the heat warping the wire wheels(?)
Lastly, I am considering a coat of Eastwood Diamond Clear (gloss or semi). I have heard this adds a level of protection. I also think it may make them a bit easier to clean as well as give them a little extra pop.
Let me try and figure out how to add a photo of my current wheels...
Happy New Year
RJS
Let see if this worked:
RJS
One more (now that I figured out how to add pictures!)
Twosheds
British Wire Wheel says to use PVC tape instead of the band. It can be found at Home Depot or equivalent or from British Wire Wheel. Don't stretch it when you are installing it and cover the nipples with two layers.
Don'y use duct tape.
glemon
I had a 4A years ago, started out with a 195 on it, went to a 165/80. Liked driving the car MUCH better with the 165s, steering was lighter and the whole car just felt lighter and more responsive. Think you are headed in the right direction.
RJS, nice looking 4A, I had a '66 solid axle.
trfourtune
I'm not a fan of powder coating since it is not easily repairable. That's just me. I prefer a properly applied urethane enamel like dupont imron. If i recall, someone had a mercedes code number for wheel paint colour that was very close.
Coatings on wire wheels need to be quite flexible since wire wheels flex a lot!
Rob
HerronScott
Wasn't there a thread here a while back about powedercoating wire wheels where a couple of people reported having problems with it warping the rims due to the heat?
I believe that I had a Corvette silver that I used on mine but I can't seem to find the paint code.
Scott
dklawson
As Scott said, there was a thread last fall talking about how to paint wire wheels and there were more stories of powder paint problems (warpage) than success. The most common recommendation in that thread were for the wheel paints sold by Eastwood.
Geo Hahn
tdskip said:
...Here is the link... www.tires-easy.com
That's who I used for the 165/80s Nexens I mounted to wires. Totally satisfied with both the tire and the company. Just don't try www.tire-easy.com (singular tire) unless you habla Espanol.
However, when I was about to order Bridgestones from them I also called my local Discount Tire for their 'cash & carry' price. Thet were happy to beat the online price. I felt better spending the $$$ locally, getting the tires immediately and in the unlikely event of a problem being able to resolve it face-to-face.
So you might find the tire & best price and then call your local Discount Tire shop to see what they can do.
<span style="font-style: italic">PS - In addition to the 165/80/15 brands mentioned, Discount Tire carries a house brand -- Arizonian -- that I have not used but know others who have and they thought it good.</span>
TR3driver
Great Pumpkin - R.I.P
I'm just curious; why is everyone so focused on maintaining speedometer accuracy? Seems like the tail wagging the dog, to me.
Personally, I love my 205/55 tires every time I pitch the car into a hard turn and _know_ it's going where I point it.
One of our local club members doesn't talk to me much any more. He has a <span style="font-weight: bold">very </span> correct TR3A, right down to the white white bias ply tires and fitted luggage. During a twisty mountain run a few years back, he complained that the leaders were going too fast ... my reply was that I felt it was so slow it was boring!
I suppose that's not quite true to the spirit of the car, but I do like it better without the "bumbling off backwards" part :laugh:
Unlikely Tractor
prb51
Randall,
I would like to try a set of bias ply just for the experience (not enuff to buy them tho).
I drive in a spirited fashion and my almost normal width radials do a nice job of hangin in there and I do like the vintage look (i.e. skinny) of the 165/80 15's
T
tdskip
Hi Randall - I hear where you are coming from. I have some meaty rubber on the TR6, and actually on the TR3 as well based on your input. In this case I'm looking for something closer to original just to have a different driving experience.
On a closed track a set of bias plys would be a hoot!
sail
RJS's set up looks hot. Geo's painted not chrome wires are the look I love. I have experienced that tires make a HUGE driving difference on any car however budget put skinny Kumhos on the original wheels with probably over priced tubes and strips from big 3. Will never change from wires (I just can't) although given the cost of mounting, tubes, pita ect I would in retrospect just have waited for sale time and gotten new wires to start with. Oh, then splines and better skinny tires than the Kumhos. Oup's, budget. All that's really needed now are a couple of spokes. I am glad I didn't go crazy cleaning up the old wheels, some steel wool and caliper gray paint...fine for now.
Geo Hahn
sail said:
...given the cost of mounting, tubes, pita ect..
FWIW, Harbor Freight sells a very inexpensive tire changer that I used for the last couple of sets I have bought. The high sidewalls of our tires make the R&R pretty easy. I was actually over-tooled with this set-up but I'm a bit old for sitting on the ground and wrassling with a couple of tire spoons.
Several ways to hold that stand in place including mounting to a sheet of plywood and, of course, just bolting it to the floor.
The HF bubble balancer was also successful in finishing the job -- I actually believe I can get a more consistent result than the tire-shop guys with the big equipment.
R TR4/4A Tr4A, unidentified wire in steering wheel area Triumph 4
Zimmycobra For Sale Original 1966 TR4A 60 Spoke painted wire wheels Triumph Classifieds 0
B TR4/4A Advance Auto Wire for TR4A Triumph 4
T TR4/4A Converting TR4a from wire to TR6 steel wheels Triumph 7
T TR4/4A White wire question on TR4A A-type wiring Triumph 2
Stinger TR4/4A TR4A Austin Healey Wire Wheels Triumph 6
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
