TR4/4A TR4A Transmission Overdrive Plug Leak
KVH
That big fat brass notched plug seems to be leaking. I tried a new fiber gasket and it's just as bad.
Should I have used teflon tape on the short threads?
Can I reuse that fiber gasket if I remove it?
How tight do I need to get that plug. I don't want to harm the tranny fitting.
Just as importantly, should I be looking for other areas of leaking--it seems wet just a little bit above that plug.
Finally, is there a necessary tool for that plug or can I use a brass drift and tap it around? It's a bit tricky that way.
Thanks all.
RJS
I just changed my OD tranny fluid two weekends ago to Redline MT90. So far, extremely happy. The SAE30 non-detergent motor oil I was using gave a notchy third gear - especially when hot. MT90 has made this the best transmission I have ever driven, period. The MT90 is comparable to a 75W90 gear oil and I believe it spins the synchros better for smoother shifting.
Anyway, I used just a light smear of Permatex Form-A-Gasket 1A on both sides of the washer. Installed the brass cap and washer. Allowed it to dry 24 hours before filling tranny.
Interestingly enough, the Moss catalog states the fiber washer on the brass plug applies to all EXCEPT the OD tranny fitted to the TR4A IRS. Not sure what that's about but, a fiber washer came off mine and I installed a new one (the new gasket was noticeably thicker than the old). And when I filled it with the SAE30 oil 3 years ago I re-used the original fiber washer with no issues. Same gasket sealer.
As for removing and installing the brass plug, I used a short 2x4 piece of wood, caught it on the edge of one of the brass tabs and tapped it several times before it moved. Then used a strap wrench (used on oil filters) to unscrew the remaining way. Same for installation.
RJS
BTW, the "new" fiber washer I installed was not the smoothest in the world. I went on the faith that a) the Form-A-Gasket would fill-in the imperfections and b) the fiber washer would crush under the torque of the brass cap.
HerronScott
Someone on eBay sells a tool to remove the overdrive filter cap if you want to spend $58 versus using a brass drift (which is what I used as well).
eBay Overdrive Filter Cap Tool
Scott
TR3driver
Great Pumpkin - R.I.P
If you've been using a drift on the plug, chances are very good that you have distorted the sealing surface. You might be able to file it back flat.
Here's a simple tool I made in about 20 minutes:
TR3driver
And a fancier one where I bought a big socket on eBay (about $10 IIRC) and milled some teeth into it.
TR3driver
Teflon tape won't help (it's only for tapered pipe threads and these threads aren't tapered). But your favorite gasket dressing (I use Hylomar) will, along with making sure that both surfaces are flat.
DNK
See that guys, Randall's in business.
Anybody need an overdrive tool?
HerronScott
Randall,
I'd buy one. :smile:
Scott
TR3driver
Sorry, not for sale. Just trying to present some alternatives.
KVH
KVH
I could try making that tool.
Those bolts are filed flat so they fit tight in each notch, correct?
And you turn the steel plank (or plate) by hand, or just tap that with a hammer or drift instead?
TR3driver
Correct. 5/16" bolts, filed down to roughly 1/4" square.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
And you turn the steel plank (or plate) by hand, or just tap that with a hammer or drift instead? [/QUOTE]
It's just a bar, about 18" long. Maybe 3/8" thick by 1-1/2" wide. Started life as a post for concrete forms at Home Depot (which explains the extra holes). The other end is a similar "quick and dirty" tool for unscrewing the plugs in the bottom of a J-type OD.
I used it by hand, but you could tap on it if needed, for some extra torque.
J TR4/4A TR4A automatic transmission conversion Triumph 6
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
TR4_EH TR4/4A TR4A Transmission noise mystery Triumph 5
E TR4/4A TR4A Transmission swap......... Triumph 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
