TR4/4A TR4A Through 6 Diaphragm Clutch
T
TRDejaVu
Original pressure plate, not aftermarket.
Does anyone know the wear specs for the pressure plate; actual surface thickness as well as allowable wear on the spring fingers?
Do they wear out?
What goes wrong on them?
Thanks
eschneider
Even without wear on the fingers, the springs fatigue and get weak, reducing the clamping force on the disk.
I can't imagine re-installing a pressure plate with any measurable wear on the fingers. Maybe just me.....
tdskip
I may be missing something here, but with all the work involve to get / get back to this point why mess around with it?
martx-5
Because there have been a mess of incorrect pressure plates floating around out there, along with lots of horror stories to go with them.
Edit: This may be of interest...
HerronScott
I'm guessing he's read the horror stories about TR6 clutches and is trying to avoid that by using an original diaphragm. I think you mentioned that on your TR6 clutch that you recently installed that the engagement was stiff and either on or off for example.
Scott
T
TRDejaVu
tdskip, normally, I would agree with you completely, but on this it's because of what Art said above.
I know that there are different schools of thought on this https://www.vtr.org/maintain/clutch-laycock.pdf, so I want to see how feasible using an original diaphragm pressure plate is. I obtained one in a parts job lot that looks to be in good condition, but I would like to know that it's OK, hence my inspection and measurement questions.
I also have a TR4A flywheel that looks to be in excellent condition as well as a very lightly used 3 point pressure plate from that job lot.
I am trying to decide whether to go to the TR4A setup or stay original. I won't know how my flywheel looks until I pull the box, but the starter doesn't always catch so I suspect some starter ring damage.
T
TRDejaVu
Anyone used rebuilt ones from Fort Wayne Clutch? They have top feedback and the current eBay pic (item # 180515752483) seems to show the OEM style diaphragm finger setup rather than the aftermarket version.
PeterK
I know it's mixing apples and oranges, but for my HVDA 5-speed, I used the AP TR6 diaphram clutch plate with no ill effects. Granted, the HVDA uses a completely different t/o set-up but with the McLeod hydraulic t/o, it's good to go.
HerronScott
Never heard of them but I asked them what they did to the diaphragm and here's their response.
HI SCOTT , ANY WEAR CAUSED BY THE THROWOUT BEARING IS GROUND OUT ,THE DIAPHRAM THEN IS TESTED FOR PRESSURE, IF IT MEETS SPECS
WE USE IT . NEW DIAPHRAMS ARE DIFFICULT TO FIND, GIVE US A TOLL FREE CALL 1-800-258-8243, ASK FOR SCOTT OR MIKE
THANKS FRANK
Not sure why they think new diaphragms are hard to find....
Scott
T
TRDejaVu
So they base diaphragm wear on a target pressure as opposed to a wear allowance. I wonder how far above a normal pressure range that they test it to? I will drop them a line as well.
Anyone have any sort of overhaul manual that gives a wear allowance on this?
MichaelG
A few years ago I read all the horror stories when I was evaluating what to do with my 4A clutch. Please note that The TR4 does not require any constant pressure on the throwout bearing, extra springs, Gunst bearings to prevent the throwout bearing from squealing, selecting the right pressure plate to make all of this work, etc.. Just set the clearance on the slave cylinder push rod and that's it.
In the end my solution was the Magic Clutch kit from TRF..performance and feel is excellent, and it comes with the heavy duty Toyo bearing so it turned out to be the right decision in my case. NFI of course.
T
TRDejaVu
Here is the response I received from Fort Wayne Clutch to questions about allowable diaphragm finger wear, plate wear and testing.
"The rebuilt kit you see on Ebay for $119.00 is a Borg & beck clutch and has a new diaphragm in it, The diaphragm is riveted into the cover, the pivot ring has a 5 3/4" diameter. The plate would have less than .015 ground off during resurfacing. The diaphragm pressure would be a little heavier than an OE Laycock style would be.
We also have a new Borg & Beck pressure plate and disc available, it is a different style than the rebuilt, the diaphragm is crimped into the cover, and the pivot ring diameter is 6 3/8". The pressure on this clutch is even heavier than the rebuilt.
The spring pressure tester we use shows a high pressure, and a leveled pressure. The high pressure indicates the initial force required to push the diaphragm from the top of the pedal stroke to the released position, and the leveled pressure would be the pressure required to hold it in the released position.
The pressures are:
Rebuilt Borg & Beck 225 - 400
New Borg & Beck 300-575
OE Laycock 175-425 (taken from some old notes on file, and i can't confirm this one.)"
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
