TR4/4A TR4A Rear Fender Bolt Removal
Stinger
OK I surrender. If I don't loosen the rear fender bolts today, so I can remove the stainless molding, Im going to sell the TR. Ive used every tool I have, so what tool do I need to go buy that has an angle so I can remove those in the trunk???????
G
1/4 drive 7/16 flex socket with an extension on it works pretty well. If not, $25 bucks and leave the car at my house. Right tool for the job always makes things more pleasant.
sail
You didn't sell the car did you? I would be interested in hearing how this goes as another project on my someday list is to pull the rear fenders and see how it looks under there.
TR4
I too would love to see a photo or two showing where the rear fender bolts are located and how you get to them.
Good luck.
tdskip
Aren't the bolt locations in the Bentley manual? I know looking at the manual is a shocking idea coming from me, but they are in there....
Stinger
Stinger
Every time I get frustrated I threaten to sell her and I'm still amazed that I still have her! Anyway as John mentioned the 1/4 drive flex socket with extension did the trick. There is very little space on about eight of the bolts and it would be even harder if everything was rusted. My TR4A has very little rust so that helped along with a shot of PB Blaster in the wheel wells. The bolts are easier to find than to remove. A couple are under the interior trim and the rest are visible in the trunk. I needed to loosen the fenders to remove the stainless trim and now I'm considering removing the fenders completely to clean up the joint areas. I really didn't want to remove the fenders but Ill probably regret it if I miss some surface rust that might bubble the paint later.
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
M TR4/4A Rear coil springs for TR4A Triumph 4
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
J TR4/4A TR4A rear wheel cylinder source Triumph 3
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
G TR4/4A tr4a irs left rear wheel Triumph 14
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
KVH TR4/4A Rear Main Seal Leak TR4A Triumph 1
T TR4/4A Refreshing solid axle TR4a rear bushings Triumph 4
K TR4/4A TR4A Distance between trunk lid and rear overiders Triumph 5
Gerard TR4/4A TR4A IRS rear suspension rebuild Triumph 10
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
Darrell_Walker TR4/4A TR4A rear brake upgrade Triumph 12
Banjo TR4/4A TR4A solid rear axle, axle. free Triumph 8
KVH TR4/4A TR4A IRS Rear Spring Bridge Triumph 6
KVH TR4/4A TR4A IRS Rear Suspension Knock Triumph 3
T TR6 Anyone use TR6 rear springs in their TR4a IRS? Triumph 8
KVH TR4/4A Rear Main Seal TR4A Triumph 17
KVH TR4/4A TR4A--Padded Rear Interior Panel--Behind The Seats Triumph 5
K TR4/4A TR4A rear shock conversion kit question Triumph 3
Stinger TR4/4A TR4A Rear Brake Wheel Cylinder Dust Shields Triumph 5
J TR4/4A TR4A Solid Axle Rear Brake Backing Plates Triumph 17
tban52 TR4/4A TR4A rear axle removal Triumph 2
KVH TR4/4A TR4A Rear Brake Shoe Installation Triumph 7
T TR4/4A TR4a [solid axle] rear twitch-iness question Triumph 15
Banjo TR4/4A TR4A solid axle rear end for sale Triumph 0
Popeye TR4/4A Lifting the rear of a TR4A Triumph 2
WME TR4/4A TR4A Front and Rear Shock Part Numbers Triumph 1
T TR4/4A TR4A with a loose rear end / happy feet. Triumph 5
T TR4/4A TR4A - rear wheel steering. Whoa! Triumph 5
bluemiata90 TR4/4A greasing rear u-joint on tr4a Triumph 1
A TR4/4A TR4A rear suspention question Triumph 6
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
