Darrell_Walker
Well, it's been a bit since I've posted an update. I hit one snag, after I installed the pulley on the water pump, I noticed a lot of runout. The guys at Moss replaced it no problem. I also decided to get a Wizard aluminum radiator, so I was blocked for a while waiting for both of those. In the meantime I did to a lot of little piddly things to be ready.
Anyway, this past weekend I got the new pulley and radiator, and got those in. Then I went to install the serpentine belt, and it was too short. Since it was the weekend, I hit up NAPA and found another belt that was about 2" longer. But when I got in touch with Moss on Monday, it turns out that they changed the belt routing to get more wrap around the supercharger pulley, but that update didn't get into the instructions. Armed with the correct routing, the belt included in the kit was installed.
I wired up the radiator fan and the fuel pump relay yesterday. One of my goals is to do a better job with my wiring, and I'm pretty happy with how it came out.
I tried to pressurize the fuel system, and got lots of leakage around the banjo fitting on the float bowl. After some more email with the tech team at Moss, we determined that the banjo fitting was the wrong way around.
In my zeal to stop the leakage, I of course tried to tighten the bolt even more, which distorted the sealing washer. Moss is sending me new ones, but I couldn't wait, so I found a copper oil plug gasket that was about the right size. But I couldn't get that to seal, so I worked over the original aluminum washer and finally got the fuel sealed up.
With that done, I was ready to try to start the engine. And, it started right up! After warming up a bit, I pushed the choke in and it settled down to an 800 RPM idle. I don't think I've ever had the engine reliably idle that low!
I'm letting it cool down a bit so I can top off the coolant, then I may venture out for a drive, if it isn't raining (or at least, raining too hard!).
