Some more progress:
Installed the proper "cheesehead" screws in the front sealing block. Had to order these from Grainger.
Installed the oil pump (including gasket). I had to "borrow" a stud from the fuel pump, as one of the oil pump studs was stripped and I did not have a replacement handy.
Also installed the oil pan, but still need to figure out where the long bolts go - as can be seen in the photo both are incorrect! (None of the bolts are torqued at this point - no blue marks.) After some late-night research, it seems one long bolt goes where the clutch slave cylinder reinforcing rod mounts, but not sure the other.
Note: Most folks say to put the short bolt in the aluminum block at the front. However I found the blind threaded hole by the dipstick to have shortest engagement depth and put it there.
[update: see edit below] (At the end of the day it probably is not too important... all bolts have sufficient thread engagement to hold the pan.)
To prevent rust, I coated the inside of the oil pan with oil. (I did not use assembly lube given the large area - and not a friction surface.) Before mounting the pan, I cleaned the machined surface of the block with brake cleaner, and put a light coat of gasket shellac on the paper gasket. (Previously put a
thin coat of RTV between pan and gasket. Tenacious stuff that RTV... None remains internal to the engine, but you can see a few flecks of it in the photos!)
As an aside, in the middle photo, you can see the "Lang" thread chasers I bought on Amazon. Love them - good use of $40!
https://www.amazon.com/gp/product/B00DTEFSWY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
