TR4/4A TR4 Rear Wheel Studs
KVH
I've read how hard these are to remove and replace.
Has someone actully done that without the aid of a machine shop, or is the consensus that a machine shop is critical?
KVH-
Not positive, but I think the 4A may just have pressed in studs so it may not an issue for you. I haven't worked on them myself, but I have heard of several others who did not use a machine shop for working on the TR3 or TR4 rear hubs.
Randy
If your studs are the same as the TR4 and are peened on the back side, I'm not sure a machine shop will do anything different than what I did myself. I ground off the peened material so the stud could simply be unscrewed and a new one screwed back in. I of coarse did not peen the back side of the new stud, only used lock tite and have not had any issue. I did this 5 years ago and check the stud every spring to make sure it is still holding well.
I changed them all out on my 4A. Had to grind off the peening on the backside of the rear hubs before I could unscrew the threaded studs. They were not pressed just in on the 4A rear. I replaced them with a Dorman 7/16" stud from a late 80s Chevy wich required that I drilled out the original threaded holes a bit. The new studs are pressed in.
The font studs are pressed in and pressed out.
KVH -- I suppose the task becomes more difficult if you need to separate the hub to get at the backside.
I have a hub puller if you ever want to try your luck with it.
Peter,
Just to clarify, is your TR4A IRS or not? It's possible there could be a difference. Mine are both IRS but I never had to change a stud on them (I did shorten them on my original one to convert it from steel to wire wheels).
Scott
