TR4/4A TR4 Rear Wheel Studs
KVH
I've read how hard these are to remove and replace.
Has someone actully done that without the aid of a machine shop, or is the consensus that a machine shop is critical?
TR4nut
KVH-
Not positive, but I think the 4A may just have pressed in studs so it may not an issue for you. I haven't worked on them myself, but I have heard of several others who did not use a machine shop for working on the TR3 or TR4 rear hubs.
Randy
TR4
If your studs are the same as the TR4 and are peened on the back side, I'm not sure a machine shop will do anything different than what I did myself. I ground off the peened material so the stud could simply be unscrewed and a new one screwed back in. I of coarse did not peen the back side of the new stud, only used lock tite and have not had any issue. I did this 5 years ago and check the stud every spring to make sure it is still holding well.
PeterK
I changed them all out on my 4A. Had to grind off the peening on the backside of the rear hubs before I could unscrew the threaded studs. They were not pressed just in on the 4A rear. I replaced them with a Dorman 7/16" stud from a late 80s Chevy wich required that I drilled out the original threaded holes a bit. The new studs are pressed in.
The font studs are pressed in and pressed out.
Geo Hahn
KVH -- I suppose the task becomes more difficult if you need to separate the hub to get at the backside.
I have a hub puller if you ever want to try your luck with it.
HerronScott
Peter,
Just to clarify, is your TR4A IRS or not? It's possible there could be a difference. Mine are both IRS but I never had to change a stud on them (I did shorten them on my original one to convert it from steel to wire wheels).
Scott
J TR4/4A Replacing TR4 rear wheel studs Triumph 2
D TR4/4A TR4 - Rear wheel slot key removal Triumph 8
6 TR4/4A Advice on stripped Rear Hub wheel stud for TR4 Triumph 24
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
P Wanted 1963 TR4 passenger fender rear Triumph Classifieds 2
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
S TR4/4A TR4 front and rear suspension Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
M TR4/4A TR4 with Surrey Top......Rear seat upholstery assistance please. Triumph 2
D TR4/4A Seals on TR4 Solid Rear Axle Triumph 5
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
M TR4/4A tr4 zip out rear window Triumph 6
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
Willie_P TR4/4A Girling brake drums/rear innards - tr4 Triumph 6
F TR4/4A TR4 rear trim Triumph 2
Willie_P TR4/4A TR4 rear brake cyl. - what's this thingamajigger? Triumph 5
TR4v8 TR4/4A tr4 rear axle width Triumph 0
doughairfield TR4/4A TR4 Rear Hub removal Triumph 14
M TR4/4A TR4 rear sway bar installation Triumph 15
CinneaghTR TR5/TR250 TR4/RA/250 Rear Bumper Installation Triumph 3
R TR4/4A TR4-A rear fender Triumph 12
G TR4/4A tr4 rear end in a tr3a Triumph 10
J TR4/4A TR4 rear suspension Triumph 8
TR4 TR4/4A Removing a rear fender on a TR4 Triumph 7
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
Tabcon TR4/4A TR4 Rear Brake Parts? Triumph 25
M TR4/4A Last question about original rear main sealTR3 TR4 Triumph 17
SCguy TR4/4A lost link... TR4 rear shock rebuild Triumph 4
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
T TR4/4A TR4 Rear Leaf Spring Mounts Triumph 6
T TR4/4A '62 TR4 rear end clunk Triumph 10
SCguy TR4/4A TR4 rear axle piece fell of into my hand? Triumph 21
KVH TR4/4A TR4 Rear End Again Triumph 4
KVH TR4/4A TR4 Rear End Again Triumph 0
PeterK TR4/4A TR4 Rear track bar pictures and info needed Triumph 6
macino62 TR4/4A TR4 rear tube shock conversion Triumph 5
D TR4/4A TR4 rear diff pinion seal Triumph 4
KVH TR4/4A Rear Oil Galley Plug and Flywheel Bolts TR4 Triumph 6
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T tr4-rear tube shocks Racing 2
P TR4/4A tr4 rear hub problem Triumph 16
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 3
