TR4/4A TR4 Differential Removal and Seal Replacement
KVH
I've got wheels off and axles out on my TR4A. Does that mean I'll have trouble getting the flange nut loose? Do I have to make a bar tool to bolt to the flange? I'm going to replace the pinion seal and it seems like it may be too hard to leave the differential hanging there on the frame, but is that how it's done, or do most people remove the differential? Also, the manual says that if you're wanting to remove the diff, you drop the mufflers and pull the diff out the back, but it appears to me that the muffler pipes are going to be in the way no matter what I do. Am I wrong? Is there an easy trick here. thx
TR3driver
Great Pumpkin - R.I.P
"Making the bar tool" is how I hold the flange, whether I'm removing it on the bench or on the car. It's easy and cheap. Buy the bar at Home Depot (or whatever is near by), and poke a couple of 3/8" holes in it. There is a good deal of torque/force involved with that nut, and I feel a lot safer countering it directly at the flange rather than trying to use the brakes (or whatever) that might tend to shift the car off the stands.
I'd pull the diff if there is something else you need to do to it; but leave it in the car just to change the seal.
Don't have a photo under the car; but here's a shot showing it installing a side nut for an IRS diff. Even though it was supported in the vise; I pulled on the end of the bar while tightening the nut. The pivot locks on my (cheap) vise aren't strong enough to hold against that much torque.
KVH
KVH
"I'd . . . . leave it in the car just to change the seal.
Do I just disconnect the driveshaft and let the diff axle tubes roll down along on the frame until the differential is pointing down so I can get to it at the correct angle?
You know, on this new purchase, I'm not wanting to be negative, here, but the diff is leaking so badly from the real gasket and cover, and the gear lube is so clean and new, I'm concerned it was just filled for show and sale. Makes me wonder how long it was dry over the years. To me, however, it also appears that the front pinion seal was leaking. The exhaust pipe, passenger side, looks like it's been baking grease since the Johnson Administration.
Geo Hahn
Do I just disconnect the driveshaft and let the diff axle tubes roll down along on the frame until the differential is pointing down so I can get to it at the correct angle?...
Well, I have never tried it that way but on a TR4 it would not be that easy to rotate the diff for access - in any case, it's not a problem changing the pinion seal with everything else still in place, just the propshaft undone and pushed aside or up. I'm thinking the car in question is a solid axle 4A so I cannot say for sure what other ways would work.
I just used a combination of wheel chocks and hand brake to hold the works for removal and torqueing but then the car was on a lift - Randall's point about jack stands and forces being applied makes sense and a bolted bar is surer and safer and with the axle removed you have little choice in the matter.
TR3driver
With the solid axle, the entire rear axle assembly is held in place by its attachment to the rear springs. It's not going anywhere unless you disconnect it. It's a little awkward doing the seal with the diff in its usual position, but certainly not worth the hassle to take it loose IMO unless there is some other reason.
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
oldbagpipe For Sale TR4 Detroit Locker Differential $1,000 Triumph Classifieds 3
T TR4/4A salisbury limited slip differential-tr4 Triumph 7
P Wanted WTB Restorable TR4 Triumph Classifieds 2
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 Parts - Rebuilt trans, floors, 4x good 15" painted wire wheels Triumph Classifieds 9
J Wanted- Late TR4 seats or seat frames Triumph Classifieds 0
D TR4/4A Automatic transmission in a TR4 A Triumph 11
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
glemon TR4/4A Wheeler Dealers TR4 Triumph 8
Twit TR4/4A TR4 AUC878 vacuum connections Triumph 7
Rut TR4/4A TR4 in Longmont, CO Triumph 2
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Twit TR4/4A TR4 trunk badge Triumph 8
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe Wanted Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 1
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
Kurtis TR4/4A TR4 Radiator Guard Attachment Triumph 7
C TR4/4A TR4 Thoughts Triumph 15
Rut TR4/4A TR4 wood dash Triumph 26
O TR4/4A TR4 Dove Triumph 4
T For Sale TR4 / 4A Parts Lot [or lots of parts...!] Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
ckeithjordan TR4/4A TR4 Carpet Comparison Triumph 7
M TR4/4A Do MGF seats fit in TR4 Triumph 0
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
J Wanted TR3 or TR4 rolling chassis Other British Classifieds 3
Mickey Richaud TR4/4A TR4 Head Needed Triumph 4
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
richie TR4/4A ATTN TR4 Surrey Top owners! Triumph 2
Z For Sale TR4 - 4 Speed Triumph Classifieds 7
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
Z For Sale TR4 - old door cards Triumph Classifieds 0
O TR4/4A tr4 pops out of second gear on deceleration Triumph 13
A For Sale 1965 tr4 Triumph Classifieds 4
H TR4/4A TR4 squeaking Triumph 2
