TR4/4A TR4 &4A transmission counterweight?
TR3driver
Great Pumpkin - R.I.P
Not sure if they really needed it or not; but it was supposedly added to suppress an annoying buzz from the gearshift lever.
I left it off when I installed a TR4 OD & gearbox in a previous TR3A, didn't seem to make any difference.
lbcs_r_fun
karls59tr said:
Why did they need one and the 3 did not? Or do they really need one???
Here's some background and a photo.
Cheers,
T
D TR4/4A Automatic transmission in a TR4 A Triumph 13
J TR4/4A Answer to my post "help with tr4 transmission disassembly". Triumph 9
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
T TR4/4A Has anyone used steel gear bushings in their TR4 transmission? Triumph 3
J TR4/4A Odd TR4 transmission question Triumph 10
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
F TR4/4A TR4 shifter and transmission tunnel Triumph 4
KVH TR4/4A TR4 Transmission Cover: The Three Big Triumph 7
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
Mark_Barton TR4/4A Trying to replace TR4 transmission mount Triumph 13
J TR4/4A TR4 Transmission question Triumph 7
S TR4/4A TR4 Transmission Problem Triumph 5
Lucas63 TR4/4A TR4 Engine and Transmission Weight Triumph 5
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
