af3683
So if the control head can move while the steering wheel is stationary does that mean that I likely have 2 issues:
1) the stator tube is damaged either at the control head or the steering box and must be replaced?
2) some of the wire connections in the control head are loose or disconnected?
Also, I fortunately happen to have a spare original control head and stator tube assembly that I was tinkering around with this evening getting ready for when I get my car. I was trying to take the back off to check the wiring, but I couldn't get access to the 3 screws in the back. They seem to be partially covered by a flat thin piece of metal which appears to have 3 cut out sections which I think are supposed to go around the screws. However, the metal piece is rotated a bit so the screws are not totally accessible. A strayed a little lubricant on it and hope that I will be able to rotate it enough to get access to the screws. Is anyone familar with this?
Sorry for all the questions. Thank you.
Art
Art
