I don't think MGB's used "adapters". The wire wheel hubs are specific to the axles while TR's did use bolt on "adapters".
Unless your MGB somewhere/sometime did get some adapters bolted to its steel wheel axles without screwing up the offset geometry.
Even if it were the latter... I believe that MGB's and TR's are different bolt patterns so if they are adapters bolted to the MGB, they won't fit your TR.
MGB W/W hubs are press fit to the rear axles and made into the front assy. Someone could have put put TR w/w adapters on the MG. Bolt patterns are the same. Many years ago I used TR3 w/w adapters to put w/wheels on a MGA. I have several TR w/w adapters set if any one is interested.
