TR2/3/3A TR3A VS TR4 Long Tube inlet manifold
BobbyO
Are there any advantages/disadvantages to using a TR4 long tube inlet manifold on a TR3 engine with H6 carbs or should I use the shorter TR3 inlet manifold?
B
BobbyO
The long tube inlet manifold is 3/8 inch bigger than a standard TR3 inlet manifold. I suspect there's a good possibility the air cleaner would hit the inner wing. Part of why I asked the question.
If you use the original air filters I believe they will hit or be very close. Let use know how it works if you do it. I have a TR4 engine I plan to use in a TR3. I will be changing out the front mounting plate.
Marv
TR-3rg
Hi,
I have the setup you are asking about. My 3a has the small port 4a head in it so I wanted the matching 4a intake. I use the H6 carbs that came with the car. Heres what I found:
1. Stock air filters will hit the fender well. I made a set of filters with tapered K&N filters. I offset them vertically about 1". I have about 1/4" fender clearance. Adjusting the fwd carb jet nut is a pain.
2. The stock throttle linkages binds up. My manifold is about .62" longer than the 3a manifold. I also think the mounting angle is different. I went to a cable.
The HS6 carbs would fit a lot easier. The H6 carb is 5.5" long, I think the HS6 is somewhere in the 4" range. I installed a header at the same time I swapped intakes so I did not get a direct comparison. It does run well.
Good Luck, Roy
B
BobbyO
Seems like a lot of work for not much, if any, benefit. Think I'll go with the stock TR3 inlet manifold. Thanks.
karls59tr
Bronze
I've been running a 4A manifold on my 3A for years. I mounted the round mesh and foam air filters. I had to push the bottom of the front filter in slightly for clearance. I didn't notice any fouling on the throttle linkage but I'd be interested in seeing a picture of the cable set up. I believe the 4A intake would be advantageous for better engine breathing.
Simon TR4a
Kastner says the 4a inlet manifold flows significantly better, but how much improvement you would get on a stock engine I do not know.
Don Elliott
For a late TR3A I restored where the owner had a long TR4 intake manifold, I had to use very thin air filters but they are not fully circular. There is a flat that I adjusted so the filters fit on. But the owner felt that the engine was not getting enough air flow through the thinner filters hence lower output power.
I also saw a photo where someone had taken a 5 pound hammer and bashed his inner fender about 2 inches so that the common air filters would fit without hitting to inner fender.
M TR2/3/3A Upper Fulcrum Orientation On TR3A with Late TR4 Upper Control Arms Triumph 6
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T TR2/3/3A How can I bend TR4 air filters to keep them from hitting fender on TR3A? Triumph 1
T TR4/4A Want to buy tr4 tranny for my tr3a Triumph 17
F TR4/4A Lightened Flywheel for TR3A/TR4 engine Triumph 12
Geo Hahn TR4/4A TR4 / late TR3A Starter Pinion Triumph 4
B TR4/4A TR4 to TR3A Rack & Pinion swap Triumph 4
G TR4/4A tr4 rear end in a tr3a Triumph 10
G TR4/4A TR4 Tranny in TR3A Triumph 8
M TR4/4A TR4 seats in a TR3a Triumph 1
gubba TR4/4A 1960 TR3A with tr4 motor and tranny? Triumph 22
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
