TR2/3/3A TR3A Vinyl Dash Covering?
Tinkerman
Has anyone covered their dash with vinyl? I don't have a problem covering it I'm wondering how I stretch it around the two lower corners and the corners in the instrument cluster pocket. My attempts with scrap pieces have proven futile. I have tried some heat but I know that there is a fine line before the heat becomes too much and melts the material. We have only one upholsterer in town and he told me that he uses a steam gun. I asked him how much to do mine and he told me maybe he could get to it by August or September, ugh! My wife has a steam wrinkle remover but I don't think it produces enough steam to help much.
Any thoughts would be much appreciated.
Any ideas on steam guns would also be appreciated.
Thanks, Tinkerman
TexasKnucklehead
Tink,
I used a marine grade (mold resistent) vinyl from a local sewing store. It seems much more 'stretchy' than normal stock. I used white on the dash, and black on the glove box cover. I think it turned out pretty good and have pictures I could share of my process. (I cut a keystone of 3/4 plywood and rounded the corners to match the indentation for the guage cluster and compressed it while the glue set.) I have a few small wrinkles around the steering shaft -and that's probably a difficult area no matter the material. I used no steam, heat, water, forms or anything but glued isolated sections day by day until it was done -about a week. The grain isn't as pronounced as leather, but neither is the price. I have yet to do the dog legs and other parts, but I'm sure the color will match perfectly.
Jer
apbos
Dick
When I did mine I made release incisions and triangular cut-outs to allow me to fold over the vinyl to the back side of the dash. Did not use any heat and made sure I had contact cement on all the surfaces I intended to have the vinyl stick too. Don't forget the small clips used to keep the vinyl in place on the bottom of the dash. They are very useful, becuse they let you get a pull on the vinyl when you are bring it over the dash lip. Matrix-5 did a write-up on this some time ago. Maybe Art will put in his 2 cents.
Paul
martx-5
I was going to chime in here, but the OP is using vinyl, and I used leather, which I think reacts differently then vinyl. Anyway, there is a bunch of pics and talk in this thread about how I did things.
Maybe it will help.
BTW Paul, that dash looks great.
Tinkerman
Tinkerman
Thanks for the pics! I'm glad to see that it can be done and done very well judging by the pictures. Both dash's look great. I have your pictures Art and they have been studied heavily. A friend is coming over today to give me an extra set of hands so we're going to start gluing and nipping and tucking and see how it comes out. I want to get this done so I can get moving on the wiring harness.
Thanks for your thought's, Tinkerman
ekamm
I am starting the same process as well please keep us update with any success and tribulations. As always pictures are great help.
angelfj1
Dick: I don't know if leather was an option for the "facia" (dash-board). It seems that most were covered with vynide.
This is a lot easier than it seems. Just follow what Art has documented which is excellent.
This is how I did my facia. Now that the weather is warm you can put your sheet of vinyl in the sun while you brush or spray your contact cement on the facia.
<span style="font-style: italic">(NOTE: I used something new recently - contact cement in gel form. I used it for a veneering project and I like it - no drips. You might consider using this instead of the regular liquid type cement.)</span>
Only apply the contact cement to the front, flat surface of the facia. You will deal with the curved edges and back surface later, and you don't need any extra cement that will attract and stick to everything. You want the vinyl to be nice and pliable. Then apply the contact cement and let it dry. Before the next step, be sure the contact cement on the vinyl AND facia is dry. With the vinyl finished side down (glued side up) on a flat surface, carefully align the facia over top and lay down onto the vinyl. You only get one chance so take it slow. Let this dry and later you can do your cut outs for the gauges and all of the little "pie slices" to get a nice, wrinkle free radius.
Good luck
vivdownunder
Having retrimmed a few TR dashes, I only ever use the contact gel that Frank mentions in his NOTE. Go easy with any heat as it can dry out the adhesive on the vynil before the coat on the metal.
Gel goes on like smooth peanut butter, avoiding all those long runs that drive you nuts with liquid contact adhesive.
I've found a toothbrush to be the best applicator for applying the gel exactly where you need it. Stand it a glass of water between coats, then just give it a good shake and wipe with a rag before starting the next section.
Note that vynil stretches one way but not the other. Test beforehand, as the right way around is needed to avoid wrinkles, especially with the S cappings.
Regards,
Viv.
TexasKnucklehead
Also, be careful what kind of paint you use on the dash. Something I used ended up getting soft and peeling off when the glue was applied. I had to strip and paint it all over. -Maybe I didn't wait for it to dry long enough?
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
Lukens TR2/3/3A TR3A seat pan. Vinyl covered? Triumph 9
NutmegCT TR2/3/3A TR3A sidescreen vinyl seal Triumph 13
Tinkerman TR2/3/3A Interior Vinyl on the Wheel Arches TR3A Triumph 9
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
