I really got a lot accomplished this weekend... Got the drive shaft out Fri evening and I had to cut one of the bolts with an angle grinder! Job done... Threaded the bypass and put in a flow restrictor.. ordered a new hose and clamps today.. Fitted the new headers and carbs... need to move the passenger side heater fitting to make room for the TR4A manifold..Working on that this week... Got the choke figured out.. Headers were sent to Jet Hot today... Raditor with fan is in and only needs a couple of wires connected to be functional, I decided to get power from the horn as it has a 35 amp circuit and I won't have to run a wire to the fuse block. I picked up power for the relay from the + side of the coil...It's only on when the key is on...I have all the right and left side side done.. I disconnected and plugged the pressure switch and rotated the brake lines 90 degrees to give room for the headers. I'm going to put a manual brake switch on the petal... I found a bad wire in the harness and stripped it back then covered it all with shrink tubing... I also covered all wiring bend over clips with shrink tubing... Really looking good I think!
Here's some pictures of the progress....
Gary Martins Carbs...
Here's what I shipped to him.. Purchased on ebay
https://www.capt-roys.com/shipped.jpg
What I received back...
https://www.capt-roys.com/gotback.jpg
The new look...
https://www.capt-roys.com/new1.jpg
Where I mounted the fan relay...
https://www.capt-roys.com/relay.jpg
Now I'm taking a couple of weeks off... Need to teach a few classes to make some more money.. and am headed to Mexico for Rooster fishing for Xmas... Hope to have this running by the middle of Jan...
The new look...
