CraigLandrum
Our TR3A came with no cockpit cappings so I've had to scrounge and pick them up where I could. For the two "S" shaped pieces that go directly in back of the driver and passenger door, I ordered the replacement fiberglass ones from Moss, part numbers 802-506 and 802-516 for left and right hand sides. The catalog says they need trimming. Now there's an understatement. They need trimming, widening, and remanufacture. The pieces I got are well-built and are substantial enough, but they are about a 1/4 inch too narrow. There is absolutely no way that I can cram them down over both the outside and inside of the body wall where they are supposed to go - and I still hav eto cover them with the thick vinyl I'm using. Sanding the insides down would get me about 1/32 or 1/16 at the most - not nearly enough. The only solution I can see is to use a bandsaw and split these things down the middle and fill the gap with more epoxy and fiberglass to allow them to fit.
Has anyone else ever used these things? Did you have the same problem? How did you solve it? Is there some magic substance that will make these things pliable enough to fit onto the car? Makes me wish I had held out for some rusted steel versions that come up on eBay....
