TR2/3/3A TR3A Fan recommendations wanted
TruCraft said:
So if the stock 4lb cap doesn't un-seat and let water flow out the over-flow hose, why should I need a higher pressure cap?
The main reason is that the higher pressure provides a higher margin before the coolant boils. Each psi of pressure raises the boiling point about 3 degrees F. But the higher pressure also improves cooling slightly, essentially by improving the contact between the water and engine/radiator.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]My heater valve is closed, so does that mean the heater core doesn't see radiator pressure?[/QUOTE]Unfortunately, the other side of the heater is still connected; the valve only closed one side. So it will still see roughly the same pressure, at least under some conditions.
I don't know if 10 psi would be a problem for a stock heater core in good condition; it might be OK. I just meant that it is the area that would concern me the most. Many years ago I 'helped' someone with their TR3A ... replacing the radiator cap with one that held the proper 4 psi (his old cap didn't hold pressure at all) was enough to blow the heater core apart!
But come to think of it, one of our local club members accidentally installed a long-reach cap on a short-reach neck (forgot that he had made the same modification I mentioned); and his upper radiator hose blew up first. I don't know for certain that his car had a heater, but I think it did.
Randall I kinda remember that from high school!
Higher pressure = water boils at higher temp.
A vacuum will make water boil at a lower temp.
I will leave the 4 psi cap on for now, but will get a 7psi cap from Moss ($7) for backup.
Drove the TR3 today about 82 degrees this morning.
At a constant 60mph the temp gauge stayed at about 160.
Even with a few stops it never went past 180.
Stopped in the drive and let it run a few minute then shut it off.
Temp went to about 195, but didn't blow any water out the over flow!!
So everything looks good.
Thanks for the help.
Lyle
