TR3A Clutch MC stop bolt and clutch slave adjust
Is there a set length to the bolt stops in the MC box for the TR3? I believe I have my new clutch master cylinder and slave cylinder adjusted pretty close but the pedal returns about 80% of the way then hesitates returning all the way back to resting position sometimes. Unless I have to adjust the threaded rod on the slave a little more? Also there are three holes for the return spring on the anchor plate. When is that needed for adjustment? And the shaft also has three holes .....is the middle one used most commonly and at what point would you go to the top or bottom one for adjustment?
