Well, my handbooks show the tail/stop bulb for a TR3-4A as a Lucas 380 with a 21 watt stop filament. I don't find 1036 in my charts, but a 1034 is listed at 23 watts and 1157 is 26.8 watts. (2357 is 28.5 watts).
But that doesn't tell the whole story. Incandescent bulbs have an odd characteristic, the filaments have much lower resistance when they are cold than when they are white-hot (ie operating). That means there is a big surge of current when they are first powered on (which is why bulbs so often burn out just as you turn them on). The 2357 in particular is optimized for more light output per watt (at the expense of shorter operating life), which is achieved partially by running the filament hotter. That means it has a bigger change in resistance from cold to hot, and hence more in-rush current than it's rating would suggest.
Thinking back, it may have been only a few months from the time I 'upgraded' to the 2357 bulbs, until the factory switch gave out.
