TR2/3/3A TR3 Wiring harness- with or w/o connectors?
newmexTR3
Hey guys,
Do any of the new 3A wiring harnesses come with the bullet connectors installed already? Or do you have to solder them yourself?
Cheers,
Gavin
If you have a pre-60000 TR3A, they came originally with bullet connectors. If you want to order a new wire harness and you want to keep it looking original, order it that way. If your supplier says he can't do it, go to any of the 3 or 4 other wire harness experts who make them or repair them, or have your old one re-covered like I have done on my TR as well as on another I restored in 2006. My 1958 TR3A came with the bayonet (bullet) connectors and many have been there for 51 years. But the cotton cover was newly done in 2007.
I got one on ebay, with a Moss Motors label on the bag. All bullet connectors were in place where they were supposed to be. Lay it out -- plug it in. Easy!
Thanks Don.
I have a post 60,000 3A, so I need one with the bullet connectors. My wiring is just shot at this point- very brittle and more of a liablility than anything.
How about Rimemr bros- I keep hearing good things about their harnesses. Do they come w/ connectors in place?
Thanks!
Don't forget to tug on each connector to make sure it has a proper mating to the wire before installation. I've found a few loose on new harnesses for previous cars.
Gavin-
I'm away from the house for a few days, but I can check the Rimmers harness I bought for a post 60000 when I get back. Fairly certain all connectors are in place - and Rimmers beat any U.S. price I could find by about $100 when they had a 20% sale going, delivered.
Randy
That sounds backwards.
I think what Gavin means is that he needs the harness with the Lucar connectors. All the harnesses have some bullet connectors, but the early ones had a lot of screw on connections that had no terminals...just bare wire.
Yes. That is what I meant. Thanks Art.
From TRF: "WIRING HARNESSES,
TR3A, TR3B,
after comm. no. TS60000; similar to
previous listing but with plug terminals
for control box, fuse box, etc"
Thanks for all tips guys. Rimmers has one for about $200.00 US. TRF's vinyl-wrapped one is 270.00. The cloth ones are even more.
Gavin-
And if you can wait, Rimmers will take 20% off that price with a sale.
Randy
Yes, don't do what I did. I bought a pre-60,000 harness as it was on offer. I spent ages soldering spade connectors onto it!
Of course, the other alternative is the wiring harness/Power Block assembly from Advance Auto Wire. This way you get to spend twice as much money and six times the amount of time installing it. :laugh:
I got it for my TR3, and glad that I did. Although it was a ton of work, the end result is superb. Below is a pic during installation. :sick:
Edit: Better make that <span style="font-weight: bold">TEN </span> times the amount of time to install...probably 30-40 hours!
TR4nut said:
Gavin-
Randy
Randy, et al: Maybe this should be a new topic, but I recommend caution when charging international purchases on a VISA card. I just had a rude awakening. I just charged $1000 as deposit on a vacation trip to Calgary, Canadian Rockies, etc. I just got hit with a $30 "international service fee", because the travel bureau is located in Vancouver. BC. I called the bank and they pointed the finger to VISA. I am sure that this was in my credit card agreement (the fine print notes), but I still think it sucks. What makes an electronic transaction between the US and any other country different and a justification for a flat 3 percent service charge. It must be that metric bump in the fiber optics cable! :madder: :madder: :madder:
