TR2/3/3A TR3 Water Temp Sensor Installation Problem
luke44
Has anyone run into a problem installing the sensor into the thermostat housing on the TR3? The threads just don't want to catch. Yet the threads are from a brand new/rebuilt gauge and seem fine. I’ve at least figured out it is 5/8 x 18 thread and not pipe thread, so, do I try a 5/8” x 18 bottoming tap which will cost me $26.00 to buy for a once in a lifetime use, or do I try a grade 8 bolt and may be cut a couple of slots in it with my die grinder and try to make a pseudo home made tap? Or a $49.00 new housing...Or, does anyone else have another other ideas? Frustrating. What should have been a 2 minute job to button it up has blown my whole afternoon :confuse: ... All comments welcome.
Yeh your housing is screwy. You should be able to buy a cheap tap and chase it clean. I usually use grease when I fit something like that, but clean it out before you damage the gauge. Or yeh just run a bolt in there and see if you can clean it out.
You should be able to get a tap on ebay for around $3.00 plus freight. I just got one for the head water jacket plug 1"x 12 for $5.00 bucks. Or as mentioned above try a bolt to clean it out.
I thought there was an adapter that threaded into the housing and then you'd insert the temp probe into that adapter fitting. The new gauge that I bought came that way.
It depends on the gauge, probably. I've bought several aftermarket gauges that came with an assortment of adapters; but no adapter was needed for the TR.
Looking at he picture,even if I had the correct tap on hand,I would clean that first cross thread area with a small scraper or pic.I have an assortment of little boring bar tool bits,but you could quickly make a good tool,out of even a bent over and groung file tang or screw driver.Start about 1 thread in and scrape , following the grove back to the begining.Should be easy in the soft housing.
Tom
Is the length of the expansion bulb for the new gauge the same as the one you are replacing? On A-series engines there is an adapter used to move the expansion bulb out further in the head casting. This same adapter is mentioned on Tegler's web site when you want to fit a mechanical temp gauge to a Spitfire. (Mini Mania part 11K2846).
If you are convinced that it is just that the threads need chasing, do not use a 5/16-18 bolt in your die grinder. Go to the hardware store (ACE or Tru-Value) and buy a 5/8-18 bolt. Use a cut-off wheel in your die grinder and cut some slots axially down the length of the threads. That will become a home made tap for the sole purpose of cleaning the old threads.
When I put mine back in (had soaked it in PBlaster everytime I was under the bonnet for about a year) I wrapped it with teflon tape. Not for the sealing effect but just to improve the chance of removing next time w/o fuss.
Thanks for the input guys. All fixed! First of all I went to my local Ace Hardware and bought a 5/8 X 18 nut and and a grade 8 bolt.
Step one was to check the fitting on the temp line - no problem there - spun on easily using fingers.
Then I tried the grade 8 bolt in the casting - if this didn't work I was going to go to plan B and cut a few slots in it to make pseudo tap. (Plan C was a tap.) Anyway, the good news was the bolt, while a bit tight, did go...
Then insert a rag and clean out the gunk...
A light oiling of the fitting...by the way, I stayed away from teflon, as this is normally used with pipe thread (as George points out, it won't help with the sealing). What's interesting about this fitting, is it gets it's seal by compressing the tapered end of the brass fitting, not the threads themselves...
And voila! Good to go. It may not look like its in all the way, but she's tight. As long as the taper on the fitting is seated tight and being compressed, you get a seal.
Hopefully this posting helps those who come after. It was puzzler at first, because normally you <span style="font-style: italic">would</span> expect a pipe thread fitting here. Not the case though. And pipe thread also has +-18 threads per inch, but, completely different and not interchangeable.
BTW -- It looks like you don't have a lock tab (Moss p/n 838-560) on the bolt that holds the generator link:
I drove for years w/o one -- until the day the bolt fell out (somewhere in New Mexico).
Geo Hahn said:
I don't know how you work on that thing with all that blinding chrome and shiny clean metal.
Hah! It's funny you should say that - check out the posting 850518 I just made in this thread here. I keep telling myself if I keep at it, one of these days I may actually drive this beast.
You are probably right. My biggest problem was I inherited a disassembled and poorly labeled box of parts that had been started but abandoned - a big challenge when you don't do the disassembly. It has often felt like building a jig saw puzzle without the picture. Half the job was figuring out what I had, and what was what, let alone how it went together. This board has been invaluable - that's why I try to post my issues as they come up. I know others are coming along behind. I'll check out the lock tab. Thanks.
luke44 said:
Ouch! 838-560 - $7.75!!
My reaction too. I made one from a fender washer in a few minutes at the grinder. I had one on the other TR to look at -- I can send you a pic.
Later...
An original locktab:
And the one I made:
I see I also used a lockwasher, guess I didn't trust my own work.
Right, won't help with sealing. But I use teflon paste on mine, because it DOES help with getting it apart next time. And I once ruined an otherwise working original gauge, trying to dig the sender bulb out of the Tstat housing. I smear the tapered section of the bulb with it, as well as the threads on the nut.
TR3driver said:
... And I once ruined an otherwise working original gauge, trying to dig the sender bulb out of the Tstat housing.
Had this problem once, and wound up removing the t-stat housing and gently tapped and pushed from the inside. Saved the bulb and gauge.
I'm glad you got this sorted and for only a small financial investment.
Geo mentioned Teflon tape to keep the threads from seizing. That's a good idea. I have always used anti-seize paste for that purpose but I think the Teflon tape would do a better job.
As for the thread type... for whatever reason 5/8-18 taps are on most LBC engines I have seen. It's a common size for almost every Smiths temperature sending unit, it is used on intake manifolds for barbed fittings, on A-series engines it was used for banjo bolts for external oil feed pipes. I'm not sure why that was chosen over pipe threads but I eventually broke down and bought both a tap and die in that size.
Where do you get the whole Temp line and sensor. I had the gauges restored at N.Hollywood Speedo but they didn't install the temp sensor or oil line.Help would be greatly appreciated. Jim
