Don't quite understand that bit.3798j said:He's also placed small squares of plywood under the tires to make any tie rod adjustments easier.
bigjones said:Fair enough.
Cheers!
Only problem is, they assume that the sidewalls of the tire are perpendicular to the axis of rotation. If your tires have raised letters, or aren't formed just exactly right, or your wheels aren't perfectly true; you may not get accurate results.This14u said:For me they are alot quicker and I get more accurate results.
