TR2/3/3A TR3 Starter removal
RonR
Folks,
It appears to me that the carbs have to removed to get the starter out of the engine compartment. This may also be true for removing the generator. Is this corect or am I missing what I hope is a very simple procedure/path?
Thakns,
Ron
Geo Hahn
I have never had to remove the carbs. You may find it helpful to undo the choke linkage to the rear carb and let it swing down.
Once you have the 2 bolts holding the starter to the bellhousing undone you should be able to withdraw the starter thru the open space below the manifolds. Probably not best practice but I usually just use the big cable (undone from the solenoid but still attached to the starter) to pull it up and out.
Note: This assumes you have a stock manifold. Also, I have the early 'bomb' starter though I think the later (post TS50000) starter will come out the same way.
As for the generator -- have also R&Red that w/o getting anything else out of the way. Helps to be able to see around corners and have anice assortment of wrenches and extensions.
Geo Hahn
Apparently that is how the factory recommended servicing them as shown by this photo demonstrating how to easily free up a jammed one:
TR3driver
Great Pumpkin - R.I.P
I figured you just had to pull the engine!
sp53
The later starters can be removed from the bottom. If it is an early one, I remove them the way Geo suggested. The first time I undid an early one I was convinced it would come out the bottom, but no; it just looks that way. The generator back bolt is kinda tight and so is the front one and so is the area it is contained in, but you do not have to remove the carbs.
TR3driver
Probably it varies by car, but on my 3A I could get the early starter out the bottom by prying on the exhaust pipe.
That stud is just copper and not very big, so it scares me to pull the starter out by the cable. And replacing the stud is a definite PITA, although I have done it successfully.
K TR2/3/3A TR3 starter dog bolt removal.... Triumph 9
gsalt57tr3 TR2/3/3A TR3 starter removal Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
tinman58 General Tech TR3 Starter Triumph 11
N TR2/3/3A TR3 Starter rebuild Triumph 3
M TR2/3/3A TR3 starter part need Triumph 3
J TR2/3/3A ? on removing tr3 starter? Triumph 16
af3683 TR2/3/3A Late TR3 Starter Triumph 3
NutmegCT TR2/3/3A 1959 TR3 - dying starter? Triumph 4
af3683 TR2/3/3A TR3 Starter Lubrication Triumph 5
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
D TR2/3/3A Removing TR3 'starter' bolt Triumph 3
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
W TR2/3/3A TR3 STARTER SWITCH ASSEMBLY PROBLEM Triumph 18
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
tinman58 TR2/3/3A Hi torque starter TR3 Triumph 2
H TR2/3/3A TR3- Who offers a good alternator kit + starter Triumph 28
M TR2/3/3A 1956 TR3 starter length handle Triumph 2
S TR2/3/3A tr3 solenoid to the starter Triumph 6
M TR2/3/3A Rebuild early bomb style starter TR3 Triumph 3
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
M TR2/3/3A TR3 Starter sound Triumph 7
A TR2/3/3A TR3 starter handle length Triumph 8
prb51 TR2/3/3A TR3 Starter issues Triumph 17
M TR2/3/3A TR3 Gear Reduction Starter Triumph 5
Tinkerman TR2/3/3A Reasembly of Starter motor, TR3 Triumph 4
Moseso TR2/3/3A TR3 Starter/flywheel/tranny case Triumph 5
martx-5 TR2/3/3A Headers and Starter on TR3 Triumph 3
