TR3 -- Pull the head "while I'm in there . . ."
Once I get the shift lever out (see my other post), I'm pretty much ready to pull the engine/trans on my TR3. My question is: does it make sense to pull the head first to clean the rust and scale out of the water jackets? It's not a huge ordeal since everything is already off the motor -- just pulling the timing chain, etc. I understand the head can be a real bear to get off on a car that's been in one piece for at least 25 years, probably longer.
I'm trying to avoid the "well, while I'm in there might as well . . ." slippery slope and had intended to leave the engine alone; just put in a new clutch, clean and paint, and re-install. However, before I started disassembling the car last year, I noticed the coolant was very rusty. Knowing I was going to replace the radiator, I put coolant flush in and ran through several "add water/bring engine up to temp/drain water" cycles. It never drained completely clear, but perhaps that's the nature of the beast?
So what's the collective wisdom of the group? Pull the head so I can get in there and really clean things up? Or leave it alone and focus on getting the car back together and out on the road sometime this decade?
Here's a pic of the water pump, which probably is a good indicator of what the inside of the engine looks like.
